Rework Makefile to be makefile name independent
jafrey
Post by jafrey »
In working with the Simulink project I've run into troubles with the Makefile. It automatically generates a make file based on the project. For example chibiOS_test.mk. And then it is called with make -f chibiOS_test.mk.
However in the 'rules.mk' file it references Makefile and I get an error "No rule to make target Makefile".
I can't seem to find a way to dereference the called Makefile using make macros, is it possible to do this?
Re: Rework Makefile to be makefile name independent
I think it is not possible, why don't just call the file Makefile?
TexZK
Post by TexZK »
Why don't you create a dummy Makefile which simply includes your own? And, if I recall correctly, there's also a target hook you might exploit.
jafrey
Post by jafrey »
TexZK wrote:Why don't you create a dummy Makefile which simply includes your own? And, if I recall correctly, there's also a target hook you might exploit.
This is what I ended up doing. Simulink is also looking for a success string in the build log file. So I made a new custom target that depends on all and then had it echo back a success.
include chibiOS_Config_Model.mk
simulink: all
   ### Created and Compiled chibiOS_Config_Model
Then I made a custom make command (the default one it generates isn't very good) that calls
make -j 8 simulink
Works like a charm. I can go straight from simulink -> STM32F4Discovery board now with no errors.
jafrey
Post by jafrey »
What does the recursive call here:
$(ACOBJS) : $(OBJDIR)/%.o : %.c Makefile
do? I've dug through the make manual and can't seem to find a rule that matches that.
Good question :)
I don't remember the details.
efuentes
Post by efuentes »
I think it means that any changes to %.c or the Makefile will cause the source file to be recompiled.
