STM32F3DISCOVERY : using the I2C protocol
giazax
Post by giazax »
Hi all,
i'm using the eval board STM32F3-DISCOVERY to interface a Humidity sensor (SI7020) with the i2c protocol (ICD1 BUS).
After many attempts...i see nothing, the status variable (after the i2cMasterTransmitTimeout command) is -2(?) and i'don't know why
..so my questions are :
The required PAL settings for the board (STM32F3-DISCOVERY) are : (i used the configuration in : http://www.chibios.org/dokuwiki/doku.php?id=chibios:community:guides:i2c_trouble_shooting....
palSetPadMode(GPIOA, GPIOA_PIN9 , PAL_MODE_ALTERNATE(4) | PAL_STM32_OTYPE_OPENDRAIN) ;
  palSetPadMode(GPIOA, GPIOA_PIN10, PAL_MODE_ALTERNATE(4) | PAL_STM32_OTYPE_OPENDRAIN) ;
where
PA9 is the SCL
PA10 is the SDA
2- the i2cconfig parameters are (i have no refereces about them...so i used the same configuration for the LSM303DLCH sensor) :
static const I2CConfig i2cconfig = {
  STM32_TIMINGR_PRESC(8U)  | STM32_TIMINGR_SCLDEL(3U) | STM32_TIMINGR_SDADEL(3U) |
  STM32_TIMINGR_SCLH(3U)   | STM32_TIMINGR_SCLL(9U),
  0,
  0
i didn't find any referece about it....are these correct or not?
3 - my command sequence is :
uint8_t rxbuf[6];
 uint8_t txbuf[6];
 SensorAddress = 0x40; //is correct
 txbuf[0] = myCommand; //is correct
  i2cAcquireBus(&I2CD1);
  i2cStart(&I2CD1, &i2cconfig);
  status = i2cMasterTransmitTimeout(&I2CD1, SensorAddress, txbuf, 1, rxbuf,0, TIME_INFINITE);
  chprintf(chp, "status =  %d \n" , status );
  i2cStop(&I2CD1);
  i2cReleaseBus (&I2CD1);
the status is always -1....and i have strange results with other commands.....
what's wrong with it?
any suggestions would be appreciated
thanks in advance
giancarlo
Re: STM32F3DISCOVERY : using the I2C protocol
That code does not tell me much. Do you have external pullup resistors? are wires short? are you looking at the bus with an analyser?
You may also try a lower speed, the settings are described in details in the Reference Manual.
giazax
Post by giazax »
i have not a logic analyser, the hardware is ok (...external pullup resistors and ... wires short)
i'lltry a lower speed
thanks
giancarlo
You may consider something cheap like this one: http://www.robot-italy.com/it/zeroplus- ... lyzer.html
It is what I use at home.
giazax
Post by giazax »
hi,
in attachment the display from the logic analyser....i see nothing.
(the settings are correct, I tested the analyser with the lsm303dlhc sensor on board)
giancarlo
p.s
my configuration for the I2C2 I/O setup is :
palSetPadMode(GPIOA, GPIOA_PIN9 , PAL_MODE_ALTERNATE(4) | PAL_STM32_OTYPE_OPENDRAIN) ; //SCL
palSetPadMode(GPIOA, GPIOA_PIN10, PAL_MODE_ALTERNATE(4) | PAL_STM32_OTYPE_OPENDRAIN) ; //SDA
Do you get a trigger? start the sampling just before the transmit operation (put a breakpoint there).
Also, try enlarging the samples buffer, it is set to 2k now, put it at 64k, may be we are not seeing anything because this.
giazax
Post by giazax »
hi giovanni,
the trigger is in default...i tried with 64 k...but nothing again....
thanks
giancarlo
giazax
Post by giazax »
hi giovanni,
in attach the display for the lsm sensor on board....it seems ok
is there any pins setup and/or other parameters i missed?
thanks for any suggestion
giancarlo
Put the buffer at 64K an try to read the whole sequence, then verify if all bytes are ACKed.
giazax
Post by giazax »
ok,
i'll try.....the max buffer is 32k
giancarlo
