I see. I have had success with eclipse in the past, with my forays into Java.
Perhaps I will follow your example. I did see a guide for using eclipse on the primary site.
Anyway, thanks for your support.
Technical update- my Linux based stlink utility seems to not want to flash or to correctively update ram to run a program.
It also said something to the effect of, Note- this board does not support Swim protocol.
So..: I'm guessing thats what swm in uVision is short for. Is that also what SWD means? Cause there appears to be a jumper available for that.
Compile-time Linker Error
DrunkenDonkey
Re: Compile-time Linker Error
After using a bit keil and iar a bit I can confirm iar is the better of them, but miles behind in terms of easy to use, modern development environment, and not mentioning the price tag at all. Granted, eclipse have its drawbacks too, trying to be too universal, also setting it up for embedded development can be challenging at the start and lose you several hours, but at the end it is every bit worth it, and besides, it is one time operation, copy-paste the next
That guide about Eclipse is a bit old, I will update it tomorrow adding notes about the use with Discovery kits.
I just updated all the Eclipse-related guides and added a new guide about using ST-Link under Eclipse, please let me know if you find any error.
