ICU halt after icuWaitCapture on STM32F373 @ 3.0-git
Vooon
Post by Vooon »
Hi all,
I want to use polled ICU, but when i try to use it immediatly halts (even without indication done in SYSTEM_HALT_HOOK).
By commenting-out i found that it breaks if i call icuWaitCompletion() or I-class in lock.
Also i tried do explicit icuDisableNotifications(), and fill callbacks with empty handler, no luck.
Config:
static const ICUConfig tim2_cfg = {
.mode = ICU_INPUT_ACTIVE_LOW,
.frequency = 1000000,   // 1 MHz
.width_cb = NULL,
.period_cb = NULL,
.overflow_cb = NULL,
.channel = ICU_CHANNEL_1,
.dier = 0
Thread https://github.com/vooon/miniecu/blob/m ... rpm.c#L119
    icuStart(&ICUD2, &tim2_cfg);
    ICUD2.tim->ARR = 2000000;   // 2 sec overflow
    icuStartCapture(&ICUD2);
    while (true) {
        icuWaitCapture(&ICUD2); // BANG!
Re: ICU halt after icuWaitCapture on STM32F373 @ 3.0-git
What error message are you getting? I assume it ends up in the chSysHalt(), there should be a message pointed by ch.dbg_panic_msg.
Vooon
Post by Vooon »
I have not used jtag debugging in this project, enough debug messages for me.
Here is the result:
(gdb) run
The program being debugged has been started already.
Start it from the beginning? (y or n) y
Starting program: /home/vovan/src/UAV/miniecu/build/miniecu_v2/miniecu_v2.elf
^C0x080050e0 in icu_lld_wait_edge.isra.0.10257 () at ../../ext/chibios/os/hal/ports/STM32/LLD/TIMv1/icu_lld.c:114
114       while ((icup->tim->SR & STM32_TIM_SR_CC1IF) == 0)
(gdb) p ch
$1 = {rlist = {r_queue = {p_next = 0x20001078 <wa_log.14858.5157>, p_prev = 0x20001c68 <_idle_thread_wa.4392.5246>}, r_prio = 0, r_ctx = {
      r13 = 0x0}, r_newer = 0x200016a0 <mainthread.6362.4393.5110>, r_older = 0x20001950 <wa_rpm.15834.5156>,
    r_current = 0x20001950 <wa_rpm.15834.5156>}, vtlist = {vt_next = 0x20001f40 <ch+28>, vt_prev = 0x20001f40 <ch+28>, vt_delta = 4294967295,
    vt_lasttime = 10045}, measurement_offset = 24}
(gdb) p ch.dbg_panic_msg
There is no member named dbg_panic_msg.
So as i can see icu thread consume all time and because led thread has lowest priority i assume it as hault (communication threads also don't have time).
Perhaps previous variant whith callbacks is better for this application.
The function icuWaitCapture() is meant to operate in polled mode, it waits for a capture to be available. If there is no signal in input the function stays in the loop indefinitely, probably this is the problem you are seeing.
I will look into adding a timeout capability on timer overflow.
Vooon
Post by Vooon »
I rewrote back to the callbacks, but there was another problem: icuGetPeriodX() returns only 0 or 1: 0 before the first event and 1 after.
Interrupts occur (updated last_update), but the value is not correct.
https://github.com/vooon/miniecu/blob/m ... _rpm.c#L82
You are clocking the ICU at 1MHz, what kind of frequencies are you trying to measure? is it possible the pulse is too fast?
Vooon
Post by Vooon »
Normal range is 1 Hz .. 1 kHz, but usually less than 300 Hz. Test signal ~10 Hz. Also hw has small RC-filter to eliminate noise.
A similar code worked with chibios 2.6, with same signal generator from blinking arduino :).
Uhm, looks really like a bug, tomorrow I will give the ICU driver a try again, today I made some more changes to it (that timeout thing to the wait function).
I also see you set manually the "overflow" limit, not a bad idea actually.
This is the new behavior of the driver, overflows change the driver state back to waiting:
Vooon
Post by Vooon »
Giovanny,
Found one bug in icu.h 183:
#define _icu_isr_invoke_width_cb(icup) do {                                 \
  if (((icup)->state == ICU_ACTIVE) &&                                      \
      ((icup)->config->period_cb != NULL))                                  \
    (icup)->config->width_cb(icup);                                         \
} while (0)
Checked wrong callback.
I added empty_handler for width_cb, but i still get 0 or 1.
Also i tryed icuGetWidthX() in period cb and get same 0 or 1.
