Test is starting at time 3337ms, ending at 4337ms, which seems to "nearly" meet the 1000 ms timeout requirerment of the test.
Test is using
test_assert_time_window(time + MS2ST(1000),
time + MS2ST(1000) + CH_CFG_ST_TIMEDELTA,
"out of time window");
I haven't set CH_CFG_ST_TIMEDELTA as i'm not runnning in timeless mode.
test_assert_time_window, is implemented using chVTIsSystemTimeWithinX which translate into
(bool)((systime_t)(time - start) < (systime_t)(end - start));
Is the test_assert_time_window too restrictive using " < " or do I have really a problem with the port?
thanks
