Test case: out of time window
sdalu
Been thanked: 2 times
Post by sdalu »
I'm working on nrf52 port, I've got one test case failing with "out of time window" (3.2)
Test is starting at time 3337ms, ending at 4337ms, which seems to "nearly" meet the 1000 ms timeout requirerment of the test.
Test is using
    test_assert_time_window(time + MS2ST(1000),
                            time + MS2ST(1000) + CH_CFG_ST_TIMEDELTA,
                            "out of time window");
I haven't set CH_CFG_ST_TIMEDELTA as i'm not runnning in timeless mode.
test_assert_time_window, is implemented using chVTIsSystemTimeWithinX which translate into
  (bool)((systime_t)(time - start) < (systime_t)(end - start));
Is the test_assert_time_window too restrictive using " < " or do I have really a problem with the port?
thanks
Re: Test case: out of time window
I see, don't worry, it is a problem with the test, I will change it.
You port is likely OK if other tests pass.
I committed a fix for that test case, it should be fine now.
