Got error in openOCD F401RE Topic is solved
ep.hobbyiest
Has thanked: 4 times
Post by ep.hobbyiest »
i am using NucleoF401 and chibi studio. I got error while opening configuration using openOCD.
i took stm32f4discover.cfg file. and i got following error.
Open On-Chip Debugger 0.10.0-dev-00325-g12e4a2a (2016-07-14-11:32)
Licensed under GNU GPL v2
For bug reports, read
Warn : Interface already configured, ignoring
Error: already specified hl_layout stlink
adapter speed: 2000 kHz
adapter_nsrst_delay: 100
none separate
Info : Unable to match requested speed 2000 kHz, using 1800 kHz
Info : clock speed 1800 kHz
Error: open failed
in procedure 'init'
in procedure 'ocd_bouncer'
Is it problem with board or configuration file.
Re: Got error in openOCD F401RE
Does it work with other boards or other STM32s?
ep.hobbyiest
for other board i select other configuration file and it is working. like stm32f103 and stm32f303xx.
but for NucleoF401RE only i m facing problem. I tried other board too, but same problem.
Might be issue with configuration file.
Try selecting target/stm32f4x_stlink.cfg
ep.hobbyiest
i tried stm32f429discovery.cfg, not working. but stm32f429disc1.cfg is working.
Is it ok, if i m using stm32f401xx processor and config file is different?
If it is able to flash it then it is OK.
