i am using NucleoF401 and chibi studio. I got error while opening configuration using openOCD.
i took stm32f4discover.cfg file. and i got following error.
Open On-Chip Debugger 0.10.0-dev-00325-g12e4a2a (2016-07-14-11:32)
Licensed under GNU GPL v2
For bug reports, read
http://openocd.org/doc/doxygen/bugs.html
Warn : Interface already configured, ignoring
Error: already specified hl_layout stlink
Info : The selected transport took over low-level target control. The results might differ compared to plain JTAG/SWD
adapter speed: 2000 kHz
adapter_nsrst_delay: 100
none separate
srst_only separate srst_nogate srst_open_drain connect_deassert_srst
Info : Unable to match requested speed 2000 kHz, using 1800 kHz
Info : clock speed 1800 kHz
Error: open failed
in procedure 'init'
in procedure 'ocd_bouncer'
Is it problem with board or configuration file.
