Problem with uart_lld.c
Giapptvn1412
Re: Problem with uart_lld.c
im use kernel version 2.6.0. what's is this IRAM1, IRAM2. what value it is necessary to fill in for IRAM1, IRAM2
- RoccoMarco
- Has thanked: 83 times
- Been thanked: 67 times
Giapptvn1412 wrote:Code: Select all
#ifndef _BOARD_H_
#define _BOARD_H_
* Setup for STM32F1 board.
* Board identifier.
#define BOARD_KOSAGI_STM32F1_SENOKO
#define BOARD_NAME " STM32F103C8T6"
* Board oscillators-related settings.
* NOTE: HSE not fitted.
#if !defined(STM32_LSECLK)
#define STM32_LSECLK 32768
#if !defined(STM32_HSECLK)
#define STM32_HSECLK 0
* Board voltages.
* Required for performance limits calculation.
#define STM32_VDD 330
* MCU type as defined in the ST header file stm32f1xx.h.
#define STM32F10X_MD
* IO pins assignments.
#define PA0 0
#define PA1 1
#define PA2 2
#define PA3 3
#define PA4 4
#define PA5 5
#define PA6 6
#define PA7 7
#define PA8 8
#define PA9 9
#define PA10 10
#define PA11 11
#define PA12 12
#define PA13 13
#define PA14 14
#define PA15 15
#define PB0 0
#define PB1 1
#define PB2 2
#define PB3 3
#define PB4 4
#define PB5 5
#define PB6 6
#define PB7 7
#define PB8 8
#define PB9 9
#define PB10 10
#define PB11 11
#define PB12 12
#define PB13 13
#define PB14 14
#define PB15 15
#define PC0 0
#define PC1 1
#define PC2 2
#define PC3 3
#define PC4 4
#define PC5 5
#define PC6 6
#define PC7 7
#define PC8 8
#define PC9 9
#define PC10 10
#define PC11 11
#define PC12 12
#define PC13 13
#define PC14 14
#define PC15 15
#define PD0 0
#define PD1 1
#define PD2 2
#define PD3 3
#define PD4 4
#define PD5 5
#define PD6 6
#define PD7 7
#define PD8 8
#define PD9 9
#define PD10 10
#define PD11 11
#define PD12 12
#define PD13 13
#define PD14 14
#define PD15 15
#define PE0 0
#define PE1 1
#define PE2 2
#define PE3 3
#define PE4 4
#define PE5 5
#define PE6 6
#define PE7 7
#define PE8 8
#define PE9 9
#define PE10 10
#define PE11 11
#define PE12 12
#define PE13 13
#define PE14 14
#define PE15 15
* I/O ports initial setup, this configuration is established soon after reset
* in the initialization code.
* Please refer to the STM32 Reference Manual for details.
#define PIN_OSPEED_INPUT(n) (0U << (((n) & 7) * 4))
#define PIN_OSPEED_10M(n) (1U << (((n) & 7) * 4))
#define PIN_OSPEED_2M(n) (2U << (((n) & 7) * 4))
#define PIN_OSPEED_50M(n) (3U << (((n) & 7) * 4))
/* Input (cnf) */
#define PIN_MODE_ANALOG(n) (0U << ((((n) & 7) * 4) + 2))
#define PIN_MODE_FLOATING(n) (1U << ((((n) & 7) * 4) + 2))
#define PIN_MODE_INPUT(n) (2U << ((((n) & 7) * 4) + 2))
/* Output (cnf) */
#define PIN_OTYPE_PUSHPULL(n) (0U << ((((n) & 7) * 4) + 2))
#define PIN_OTYPE_OPENDRAIN(n) (1U << ((((n) & 7) * 4) + 2))
#define PIN_OTYPE_AF_PUSHPULL(n) (2U << ((((n) & 7) * 4) + 2))
#define PIN_OTYPE_AF_OPENDRAIN(n) (3U << ((((n) & 7) * 4) + 2))
/* Set not-present pins to floating inputs */
#define PIN_NOTPRESENT(n) (4U << (((n) & 7) * 4))
#define PIN_UNUSED(n) PIN_NOTPRESENT(n)
/* Output data (ODR) */
#define PIN_ODR_HIGH(n) (1U << ((n) & 7))
#define PIN_ODR_LOW(n)
#define VAL_GPIOA_CRL ( 0 \
/* CHG_CRIT */ \
| PIN_OSPEED_INPUT(PA0) \
| PIN_MODE_FLOATING(PA0) \
| PIN_UNUSED(PA1) \
| PIN_UNUSED(PA2) \
| PIN_UNUSED(PA3) \
/* ANA_METER */ \
| PIN_OSPEED_INPUT(PA4) \
| PIN_MODE_ANALOG(PA4) \
/* ADC_IN5 */ \
| PIN_OSPEED_INPUT(PA5) \
| PIN_MODE_ANALOG(PA5) \
/* ADC_IN6 */ \
| PIN_OSPEED_INPUT(PA6) \
| PIN_MODE_ANALOG(PA6) \
/* ADC_IN7 */ \
| PIN_OSPEED_INPUT(PA7) \
| PIN_MODE_ANALOG(PA7) \
| 0)
#define VAL_GPIOA_CRH ( 0 \
/* CHG_ACOK */ \
| PIN_OSPEED_INPUT(PA8) \
| PIN_MODE_FLOATING(PA8) \
/* USART1_TX */ \
| PIN_OSPEED_2M(PA9) \
| PIN_OTYPE_AF_PUSHPULL(PA9) \
/* USART1_RX */ \
| PIN_OSPEED_INPUT(PA10) \
| PIN_MODE_FLOATING(PA10) \
/* GG_SYSPRES */ \
| PIN_OSPEED_2M(PA11) \
| PIN_OTYPE_PUSHPULL(PA11) \
/* CHG_CE */ \
| PIN_OSPEED_2M(PA12) \
| PIN_OTYPE_PUSHPULL(PA12) \
/* CHG_PWRSWITCH2 (formerly JTMS-SWDIO) */ \
| PIN_OSPEED_INPUT(PA13) \
| PIN_MODE_FLOATING(PA13) \
/* JTCK / SWCLK */ \
| PIN_OSPEED_INPUT(PA14) \
| PIN_MODE_FLOATING(PA14) \
/* JTDI */ \
| PIN_OSPEED_INPUT(PA15) \
| PIN_MODE_FLOATING(PA15) \
| 0)
* Pull GG_SYSPRES low to enable gas gauge,
* and CHG_CE high to enable charging
#define VAL_GPIOA_ODR (( 0U << 11 ) | ( 1U << 12 ))
#define VAL_GPIOB_CRL ( 0 \
/* CHG_ICOUT */ \
| PIN_OSPEED_INPUT(PB0) \
| PIN_MODE_FLOATING(PB0) \
/* NC */ \
| PIN_UNUSED(PB1) \
/* Programming mode */ \
| PIN_UNUSED(PB2) \
/* PM_JTDO */ \
| PIN_OSPEED_2M(PB3) \
| PIN_OTYPE_OPENDRAIN(PB3) \
/* PM_JRST */ \
| PIN_OSPEED_INPUT(PB4) \
| PIN_MODE_FLOATING(PB4) \
/* NC */ \
| PIN_UNUSED(PB5) \
| PIN_UNUSED(PB6) \
| PIN_UNUSED(PB7) \
| 0)
#define VAL_GPIOB_CRH ( 0 \
/* PM_REFLASH_ALRT */ \
| PIN_UNUSED(PB8) \
/* NC */ \
| PIN_UNUSED(PB9) \
/* CHG_SCL */ \
| PIN_OSPEED_2M(PB10) \
| PIN_OTYPE_AF_OPENDRAIN(PB10) \
/* CHG_SDA */ \
| PIN_OSPEED_2M(PB11) \
| PIN_OTYPE_AF_OPENDRAIN(PB11) \
/* CHG_ALERT */ \
| PIN_OSPEED_INPUT(PB12) \
| PIN_MODE_INPUT(PB12) \
/* NC */ \
| PIN_UNUSED(PB13) \
/* CHG_PWRSWITCH */ \
| PIN_OSPEED_INPUT(PB14) \
| PIN_MODE_FLOATING(PB14) \
/* CHG_MASTERPWR */ \
| PIN_OSPEED_2M(PB15) \
| PIN_OTYPE_PUSHPULL(PB15) \
| 0 )
/* master power (PB15) on */
/* Pull alert (PB15) high */
/* Pull CHG_PWRSWITCH_EXT (PB3) high */
#define VAL_GPIOB_ODR ((1U << 15) | (1U << 12) | (1U << 3))
#define VAL_GPIOC_CRL ( 0 \
| PIN_NOTPRESENT(PC0) \
| PIN_NOTPRESENT(PC1) \
| PIN_NOTPRESENT(PC2) \
| PIN_NOTPRESENT(PC3) \
| PIN_NOTPRESENT(PC4) \
| PIN_NOTPRESENT(PC5) \
| PIN_NOTPRESENT(PC6) \
| PIN_NOTPRESENT(PC7) \
#define VAL_GPIOC_CRH ( 0 \
| PIN_NOTPRESENT(PC8) \
| PIN_NOTPRESENT(PC9) \
| PIN_NOTPRESENT(PC10) \
| PIN_NOTPRESENT(PC11) \
| PIN_NOTPRESENT(PC12) \
/* TAMPER-RTC */ \
| PIN_UNUSED(PC13) \
/* PM_OSC32_IN */ \
| PIN_OSPEED_INPUT(PC14) \
| PIN_MODE_INPUT(PC14) \
/* PM_OSC32_OUT */ \
| PIN_OSPEED_INPUT(PC15) \
| PIN_MODE_INPUT(PC15) \
| 0)
#define VAL_GPIOC_ODR 0
#define VAL_GPIOD_CRL ( 0 \
| PIN_UNUSED(PD0) \
| PIN_UNUSED(PD1) \
| PIN_NOTPRESENT(PD2) \
| PIN_NOTPRESENT(PD3) \
| PIN_NOTPRESENT(PD4) \
| PIN_NOTPRESENT(PD5) \
| PIN_NOTPRESENT(PD6) \
| PIN_NOTPRESENT(PD7) \
| 0)
#define VAL_GPIOD_CRH ( 0 \
| PIN_NOTPRESENT(PD8) \
| PIN_NOTPRESENT(PD9) \
| PIN_NOTPRESENT(PD10) \
| PIN_NOTPRESENT(PD11) \
| PIN_NOTPRESENT(PD12) \
| PIN_NOTPRESENT(PD13) \
| PIN_NOTPRESENT(PD14) \
| PIN_NOTPRESENT(PD15) \
| 0)
#define VAL_GPIOD_ODR 0
#define VAL_GPIOE_CRL ( 0 \
| PIN_NOTPRESENT(PE0) \
| PIN_NOTPRESENT(PE1) \
| PIN_NOTPRESENT(PE2) \
| PIN_NOTPRESENT(PE3) \
| PIN_NOTPRESENT(PE4) \
| PIN_NOTPRESENT(PE5) \
| PIN_NOTPRESENT(PE6) \
| PIN_NOTPRESENT(PE7) \
| 0)
#define VAL_GPIOE_CRH ( 0 \
| PIN_NOTPRESENT(PE8) \
| PIN_NOTPRESENT(PE9) \
| PIN_NOTPRESENT(PE10) \
| PIN_NOTPRESENT(PE11) \
| PIN_NOTPRESENT(PE12) \
| PIN_NOTPRESENT(PE13) \
| PIN_NOTPRESENT(PE14) \
| PIN_NOTPRESENT(PE15) \
| 0)
#define VAL_GPIOE_ODR 0
#if !defined(_FROM_ASM_)
#ifdef __cplusplus
extern "C" {
void boardInit(void);
#ifdef __cplusplus
#endif /* _FROM_ASM_ */
#endif /* _BOARD_H_ */
//// My board.h
Please wrap code usign [code] tag or forum will lose readability.
- RoccoMarco
Dear,
since you are new to ChibiOS my suggestion is to switch to 16.1 making your effort more productive.
To face initial difficulties we have wrote a lot of article
my suggestion is to read them and come back here to post if you still have problems
I am new with ChibiOS. Where do I start?
Your problem is not related to a lack of ChibiOS but to a lack of information you can easily fill.
Ciao
Ciao
Giapptvn1412
#define BUF_SIZE 160
static char UARTPrintBuf[BUF_SIZE];
static Semaphore UARTSem;
* This callback is invoked when a transmission buffer has been completely
* read by the driver.
static void txend1(UARTDriver *uartp) {
(void)uartp;
palClearPad(IOPORT2, GPIOB_LED1);
// Next line can be printed
chSysLockFromIsr();
chSemSignalI(&UARTSem);
chSysUnlockFromIsr();
* This callback is invoked when a transmission has physically completed.
static void txend2(UARTDriver *uartp) {
(void)uartp;
* This callback is invoked on a receive error, the errors mask is passed
* as parameter.
static void rxerr(UARTDriver *uartp, uartflags_t e) {
(void)uartp;
(void)e;
* This callback is invoked when a character is received but the application
* was not ready to receive it, the character is passed as parameter.
static void rxchar(UARTDriver *uartp, uint16_t c) {
(void)uartp;
(void)c;
* This callback is invoked when a receive buffer has been completely written.
static void rxend(UARTDriver *uartp) {
(void)uartp;
* UART driver configuration structure.
* uart_cfg_1 Debug console
* uart_cfg_2 GPS interface
static UARTConfig uart_cfg_1 = {
txend1,
txend2,
rxend,
rxchar,
rxerr,
38400,
//115200,
0,
USART_CR2_LINEN,
0
static SerialConfig serial_cfg_2 = {
4800,
0,
0,
0,
* Initialize the serial port
void UARTInit(void)
* Initialize the semaphore
chSemInit(&UARTSem, 1);
* Activates the serial driver 2 using the driver default configuration.
uartStart(&UARTD1, &uart_cfg_1);
* Use serial driver for second uart, because a DMA-bug prevents the use of the UART driver.
* TODO When this works well, move all to the serial driver.
sdStart(&SD2, &serial_cfg_2);
* Print formatted string to serial port
void UARTPrintf(const char *format, ...)
va_list ap;
va_start (ap, format);
* Wait for buffer to become available again.
chSemWait(&UARTSem);
* Build string to send to the buffer.
vsnprintf(UARTPrintBuf, BUF_SIZE, format, ap);
* Print stuff UART
uartStartSend(&UARTD1, strlen(UARTPrintBuf), UARTPrintBuf);
#include <ch.h>
#include <hal.h>
#include <uart.h>
#include "fc_uart.h"
#include "fc_gpio.h"
#include <stdio.h>
#include <string.h>
#include <math.h>
#include "chprintf.h"
static VirtualTimer vt1, vt2;
static void restart(void *p)
(void)p;
uartStartSendI(&UARTD1, 14, "Hello World!\r\n");
static void ledoff(void *p)
(void)p;
palSetPad(IOPORT2, GPIOB_LED1);
(void)uartp;
(void)uartp;
chSysLockFromIsr();
if (chVTIsArmedI(&vt1))
chVTResetI(&vt1);
chVTSetI(&vt1, MS2ST(5000), restart, NULL);
* as parameter.
(void)uartp;
(void)e;
(void)uartp;
(void)c;
/* Flashing the LED each time a character is received.*/
chSysLockFromIsr();
if (chVTIsArmedI(&vt2))
chVTResetI(&vt2);
chVTSetI(&vt2, MS2ST(200), ledoff, NULL);
static msg_t Thread1(BaseChannel *chp, void *arg)
while(1)
chprintf(chp,"hello ");
(void)uartp;
txend1,
txend2,
rxend,
rxchar,
rxerr,
38400,
0,
USART_CR2_LINEN,
0
* Application entry point.
int main(void) {
* System initializations.
* RTOS is active.
//UARTInit();
//chThdCreateStatic(waThread1, sizeof(waThread1), NORMALPRIO, Thread1, NULL);
//chprintf(chp,"pham tuan giap");
// uartStart(&UARTD1, &uart_cfg_1);
* Starts the transmission, it will be handled entirely in background.
//uartStartSend(&UARTD1, 13, "Starting...\r\n");
UARTPrintf("Hello world\r\n");
//chprintf(chp,"hellovietnam");
//chprintf(BaseChannel *chp, "hello world");
* Normal main() thread activity, in this demo it does nothing.
while (TRUE) {
chThdSleepMilliseconds(500);
return 0;
}I compiled successfully. But do not show uart. what error here?
- RoccoMarco
Without information about hardware, MCU used, schematic of connections how can we help you.
BTW I think you need to read these topics
How to ask for support, what to expect
Getting started with ChibiOS and troubleshoooting
Ciao
Ciao
