i do not use the LSE. So i disabled it in mcuconf.h. Futhermore i do not define STM32_LSEDRV in board.h because i do not need it. The problem is now that the percompiler throws an error in hal_lld.h because the error check is not within #if STM32_LSE_ENABLED as implemented in the hal_lld.h of the STM32F3.
Is this a bug or a misshandling?
STM32F7 hal_lld - STM32_LSEDRV
Re: STM32F7 hal_lld - STM32_LSEDRV
Those macros are assumed to be provided by the board files regardless of mcuconf.h settings.
The generator should generate those, are you creating board files manually?
OK, i think my version is not the newest. It's not generated. I have to update the toolchain. Nevertheless the STM32_LSEDRV is checked for STM32_LSE_ENABLED with other ports (STM32F3).
