STM32F7 hal_lld - STM32_LSEDRV
neums
Has thanked: 10 times
Been thanked: 5 times
Post by neums »
i do not use the LSE. So i disabled it in mcuconf.h. Futhermore i do not define STM32_LSEDRV in board.h because i do not need it. The problem is now that the percompiler throws an error in hal_lld.h because the error check is not within #if STM32_LSE_ENABLED as implemented in the hal_lld.h of the STM32F3.
Is this a bug or a misshandling?
Re: STM32F7 hal_lld - STM32_LSEDRV
Those macros are assumed to be provided by the board files regardless of mcuconf.h settings.
The generator should generate those, are you creating board files manually?
neums
Post by neums »
OK, i think my version is not the newest. It's not generated. I have to update the toolchain. Nevertheless the STM32_LSEDRV is checked for STM32_LSE_ENABLED with other ports (STM32F3).
