I am trying to bring up SDMMC1 on an STM32H743 using ChibiOS 21.11.4 and I am completely stuck.
The same board and the same SD card work perfectly with STM32Cube HAL.
With ChibiOS, the SDMMC peripheral appears to be electrically dead.
- Symptoms:
* SDMMC1 registers are accessible and writable
* AHB3 clock is enabled (`RCC->AHB3ENR` SDMMC1EN bit is set)
* SDMMC kernel clock source is configured (tested both PLL1Q and PLL2R)
* PLLs are running and stable
* `SDMMC->POWER = 0x3`
* `SDMMC->CLKCR` is programmed (e.g. `0x164`, CLKEN = 1)
But:
* `SDMMC->STA` always remains `0x00000000`
* No flags ever appear: no `CMDSENT`, no `CMDREND`, no `CTIMEOUT`, no errors
* Sending CMD0 or any command manually does nothing
* `sdcConnect()` always fails
* Even with no card inserted, there is absolutely no activity
The SDMMC behaves as if the whole peripheral block is not clocked or not powered.
- What I verified in GDB:
* `RCC->AHB3ENR` SDMMC1 bit is set
* `RCC->D1CCIPR` is correctly configured for SDMMC kernel clock
* `RCC->PLL1CR` / `RCC->PLL2CR` show PLLs enabled and stable
* The SDMMC registers can be written and read back correctly
* `SDMMC->CLKCR` has CLKEN = 1
* `SDMMC->POWER = 3`
Yet:
* `SDMMC->STA` stays at 0 forever
- What I tried
* Forcing SDMMC clocks manually in code and in GDB
* Forcing SDMMC kernel clock source (PLL1Q, PLL2R)
* Forcing SDMMC registers manually
* Using both ChibiOS SDC driver and raw register access
* Testing on several different boards (same result)
* Comparing with STM32Cube HAL project (works perfectly there)
- Question:
On STM32H743:
Is there any additional power-domain / PWR / VDDMMC / CR3 / SMPS / LDO / domain enable needed to actually power the SDMMC1 block?
Is there anything specific that ChibiOS does (or does not do) regarding SDMMC power or clock domain enable on H7?
Is there any known missing step or bug in ChibiOS 21.11.x for SDMMC on H7?
And more generally:
Is there something obvious that I might be missing in the STM32H7 SDMMC bring-up sequence?
At this point the peripheral behaves exactly as if the SDMMC block is electrically OFF.
Here are the relevant files from my project:
main.c
#include "ch.h"
#include "hal.h"
#include "chprintf.h"
static SerialConfig sercfg = {
115200,
0,
USART_CR2_STOP1_BITS,
0
int main(void) {
sdStart(&SD1, &sercfg);
chprintf((BaseSequentialStream *)&SD1, "\r\n=== STM32H743 SDMMC MINIMAL TEST ===\r\n");
chprintf((BaseSequentialStream *)&SD1, "Starting SDC...\r\n");
sdcStart(&SDCD1, NULL);
chprintf((BaseSequentialStream *)&SD1, "Connecting to card...\r\n");
if (sdcConnect(&SDCD1)) {
chprintf((BaseSequentialStream *)&SD1, "ERROR: sdcConnect failed\r\n");
chprintf((BaseSequentialStream *)&SD1, "SDMMC_STA = 0x%08X\r\n", *((volatile uint32_t*)0x52007034));
chprintf((BaseSequentialStream *)&SD1, "SDMMC_CLKCR = 0x%08X\r\n", *((volatile uint32_t*)0x52007004));
chprintf((BaseSequentialStream *)&SD1, "SDMMC_POWER = 0x%08X\r\n", *((volatile uint32_t*)0x52007000));
while (true) {
chThdSleepMilliseconds(1000);
chprintf((BaseSequentialStream *)&SD1, "SD card detected successfully.\r\n");
while (true) {
mcuconf.h
ChibiOS - Copyright (C) 2006..2025 Giovanni Di Sirio
#ifndef MCUCONF_H
#define MCUCONF_H
* STM32H7xx drivers configuration.
* The following settings override the default settings present in
* the various device driver implementation headers.
* Note that the settings for each driver only have effect if the whole
* driver is enabled in halconf.h.
* IRQ priorities:
* 15...0 Lowest...Highest.
* DMA priorities:
* 0...3 Lowest...Highest.
#define STM32H7xx_MCUCONF
#define STM32H743_MCUCONF
* General settings.
#define STM32_NO_INIT FALSE
#define STM32_TARGET_CORE 1
* Memory attributes settings.
#define STM32_NOCACHE_ENABLE FALSE
#define STM32_NOCACHE_MPU_REGION MPU_REGION_6
#define STM32_NOCACHE_RBAR 0x24000000U
#define STM32_NOCACHE_RASR MPU_RASR_SIZE_16K
* PWR system settings.
* Reading STM32 Reference Manual is required, settings in PWR_CR3 are
* very critical.
* Register constants are taken from the ST header.
#define STM32_VOS STM32_VOS_SCALE1
#define STM32_PWR_CR1 (PWR_CR1_SVOS_1 | PWR_CR1_SVOS_0)
#define STM32_PWR_CR2 (PWR_CR2_BREN)
#define STM32_PWR_CR3 (PWR_CR3_LDOEN | PWR_CR3_USB33DEN)
#define STM32_PWR_CPUCR 0
* Clock tree static settings.
* Reading STM32 Reference Manual is required.
#define STM32_HSI_ENABLED TRUE
#define STM32_LSI_ENABLED FALSE
#define STM32_CSI_ENABLED FALSE
#define STM32_HSI48_ENABLED TRUE
#define STM32_HSE_ENABLED TRUE
#define STM32_LSE_ENABLED FALSE
#define STM32_HSIDIV STM32_HSIDIV_DIV1
* PLLs static settings.
#define STM32_PLLSRC STM32_PLLSRC_HSE_CK
#define STM32_PLLCFGR_MASK ~0
#define STM32_PLL1_ENABLED TRUE
#define STM32_PLL1_P_ENABLED TRUE
#define STM32_PLL1_Q_ENABLED TRUE
#define STM32_PLL1_R_ENABLED TRUE
#define STM32_PLL1_DIVM_VALUE 5
#define STM32_PLL1_DIVN_VALUE 160
#define STM32_PLL1_FRACN_VALUE 0
#define STM32_PLL1_DIVP_VALUE 2
#define STM32_PLL1_DIVQ_VALUE 10
#define STM32_PLL1_DIVR_VALUE 2
#define STM32_PLL2_ENABLED TRUE
#define STM32_PLL2_P_ENABLED TRUE
#define STM32_PLL2_Q_ENABLED TRUE
#define STM32_PLL2_R_ENABLED TRUE
#define STM32_PLL2_DIVM_VALUE 5
#define STM32_PLL2_DIVN_VALUE 98
#define STM32_PLL2_FRACN_VALUE 2494
#define STM32_PLL2_DIVP_VALUE 10
#define STM32_PLL2_DIVQ_VALUE 2
#define STM32_PLL2_DIVR_VALUE 12
#define STM32_PLL3_ENABLED TRUE
#define STM32_PLL3_P_ENABLED TRUE
#define STM32_PLL3_Q_ENABLED FALSE
#define STM32_PLL3_R_ENABLED TRUE
#define STM32_PLL3_DIVM_VALUE 25
#define STM32_PLL3_DIVN_VALUE 288
#define STM32_PLL3_FRACN_VALUE 0
#define STM32_PLL3_DIVP_VALUE 4
#define STM32_PLL3_DIVQ_VALUE 6
#define STM32_PLL3_DIVR_VALUE 8
* Core clocks dynamic settings (can be changed at runtime).
#define STM32_SW STM32_SW_PLL1_P_CK
#define STM32_RTCSEL STM32_RTCSEL_LSI_CK
#define STM32_D1CPRE STM32_D1CPRE_DIV1
#define STM32_D1HPRE STM32_D1HPRE_DIV2
#define STM32_D1PPRE3 STM32_D1PPRE3_DIV2
#define STM32_D2PPRE1 STM32_D2PPRE1_DIV2
#define STM32_D2PPRE2 STM32_D2PPRE2_DIV2
#define STM32_D3PPRE4 STM32_D3PPRE4_DIV2
* Peripherals clocks static settings.
#define STM32_MCO1SEL STM32_MCO1SEL_HSI_CK
#define STM32_MCO1PRE_VALUE 4
#define STM32_MCO2SEL STM32_MCO2SEL_SYS_CK
#define STM32_MCO2PRE_VALUE 4
#define STM32_TIMPRE_ENABLE TRUE
#define STM32_HRTIMSEL 0
#define STM32_STOPKERWUCK 0
#define STM32_STOPWUCK 0
#define STM32_RTCPRE_VALUE 8
#define STM32_CKPERSEL STM32_CKPERSEL_HSI_CK
#define STM32_SDMMCSEL STM32_SDMMCSEL_PLL1_Q_CK
#define STM32_QSPISEL STM32_QSPISEL_HCLK
#define STM32_FMCSEL STM32_FMCSEL_HCLK
#define STM32_SWPSEL STM32_SWPSEL_PCLK1
#define STM32_FDCANSEL STM32_FDCANSEL_PLL1_Q_CK
#define STM32_DFSDM1SEL STM32_DFSDM1SEL_PCLK2
#define STM32_SPDIFSEL STM32_SPDIFSEL_PLL1_Q_CK
#define STM32_SPI45SEL STM32_SPI45SEL_PCLK2
#define STM32_SPI123SEL STM32_SPI123SEL_PLL1_Q_CK
#define STM32_SAI23SEL STM32_SAI23SEL_PLL2_P_CK
#define STM32_SAI1SEL STM32_SAI1SEL_PLL1_Q_CK
#define STM32_LPTIM1SEL STM32_LPTIM1SEL_PCLK1
#define STM32_CECSEL STM32_CECSEL_LSI_CK
#define STM32_USBSEL STM32_USBSEL_HSI48_CK
#define STM32_I2C123SEL STM32_I2C123SEL_PCLK1
#define STM32_RNGSEL STM32_RNGSEL_HSI48_CK
#define STM32_USART16SEL STM32_USART16SEL_PCLK2
#define STM32_USART234578SEL STM32_USART234578SEL_PCLK1
#define STM32_SPI6SEL STM32_SPI6SEL_PCLK4
#define STM32_SAI4BSEL STM32_SAI4BSEL_PLL1_Q_CK
#define STM32_SAI4ASEL STM32_SAI4ASEL_PLL1_Q_CK
#define STM32_ADCSEL STM32_ADCSEL_DISABLE
#define STM32_LPTIM345SEL STM32_LPTIM345SEL_PCLK4
#define STM32_LPTIM2SEL STM32_LPTIM2SEL_PCLK4
#define STM32_I2C4SEL STM32_I2C4SEL_PCLK4
#define STM32_LPUART1SEL STM32_LPUART1SEL_PCLK4
* IRQ system settings.
#define STM32_IRQ_EXTI0_PRIORITY 6
#define STM32_IRQ_EXTI1_PRIORITY 6
#define STM32_IRQ_EXTI2_PRIORITY 6
#define STM32_IRQ_EXTI3_PRIORITY 6
#define STM32_IRQ_EXTI4_PRIORITY 6
#define STM32_IRQ_EXTI5_9_PRIORITY 6
#define STM32_IRQ_EXTI10_15_PRIORITY 6
#define STM32_IRQ_EXTI16_PRIORITY 6
#define STM32_IRQ_EXTI17_PRIORITY 6
#define STM32_IRQ_EXTI18_PRIORITY 6
#define STM32_IRQ_EXTI19_PRIORITY 6
#define STM32_IRQ_EXTI20_21_PRIORITY 6
#define STM32_IRQ_FDCAN1_PRIORITY 10
#define STM32_IRQ_FDCAN2_PRIORITY 10
#define STM32_IRQ_MDMA_PRIORITY 9
#define STM32_IRQ_QUADSPI1_PRIORITY 10
#define STM32_IRQ_SDMMC1_PRIORITY 9
#define STM32_IRQ_SDMMC2_PRIORITY 9
#define STM32_IRQ_TIM1_UP_PRIORITY 7
#define STM32_IRQ_TIM1_CC_PRIORITY 7
#define STM32_IRQ_TIM2_PRIORITY 7
#define STM32_IRQ_TIM3_PRIORITY 7
#define STM32_IRQ_TIM4_PRIORITY 7
#define STM32_IRQ_TIM5_PRIORITY 7
#define STM32_IRQ_TIM6_PRIORITY 7
#define STM32_IRQ_TIM7_PRIORITY 7
#define STM32_IRQ_TIM8_BRK_TIM12_PRIORITY 7
#define STM32_IRQ_TIM8_UP_TIM13_PRIORITY 7
#define STM32_IRQ_TIM8_TRGCO_TIM14_PRIORITY 7
#define STM32_IRQ_TIM8_CC_PRIORITY 7
#define STM32_IRQ_TIM15_PRIORITY 7
#define STM32_IRQ_TIM16_PRIORITY 7
#define STM32_IRQ_TIM17_PRIORITY 7
#define STM32_IRQ_USART1_PRIORITY 12
#define STM32_IRQ_USART2_PRIORITY 12
#define STM32_IRQ_USART3_PRIORITY 12
#define STM32_IRQ_UART4_PRIORITY 12
#define STM32_IRQ_UART5_PRIORITY 12
#define STM32_IRQ_USART6_PRIORITY 12
#define STM32_IRQ_UART7_PRIORITY 12
#define STM32_IRQ_UART8_PRIORITY 12
#define STM32_IRQ_LPUART1_PRIORITY 12
* ADC driver system settings.
#define STM32_ADC_DUAL_MODE FALSE
#define STM32_ADC_SAMPLES_SIZE 16
#define STM32_ADC_USE_ADC12 TRUE
#define STM32_ADC_USE_ADC3 FALSE
#define STM32_ADC_ADC12_DMA_STREAM STM32_DMA_STREAM_ID_ANY
#define STM32_ADC_ADC3_DMA_STREAM STM32_DMA_STREAM_ID_ANY
#define STM32_ADC_ADC3_USE_BDMA FALSE
#define STM32_ADC_ADC3_BDMA_STREAM STM32_BDMA_STREAM_ID_ANY
#define STM32_ADC_ADC12_DMA_PRIORITY 2
#define STM32_ADC_ADC3_DMA_PRIORITY 2
#define STM32_ADC_ADC12_IRQ_PRIORITY 5
#define STM32_ADC_ADC3_IRQ_PRIORITY 5
#define STM32_ADC_ADC12_CLOCK_MODE ADC_CCR_CKMODE_ADCCK
#define STM32_ADC_ADC3_CLOCK_MODE ADC_CCR_CKMODE_ADCCK
* CAN driver system settings.
#define STM32_CAN_USE_FDCAN1 FALSE
#define STM32_CAN_USE_FDCAN2 FALSE
* DAC driver system settings.
#define STM32_DAC_DUAL_MODE FALSE
#define STM32_DAC_USE_DAC1_CH1 FALSE
#define STM32_DAC_USE_DAC1_CH2 FALSE
#define STM32_DAC_DAC1_CH1_IRQ_PRIORITY 10
#define STM32_DAC_DAC1_CH2_IRQ_PRIORITY 10
#define STM32_DAC_DAC1_CH1_DMA_PRIORITY 2
#define STM32_DAC_DAC1_CH2_DMA_PRIORITY 2
#define STM32_DAC_DAC1_CH1_DMA_STREAM STM32_DMA_STREAM_ID_ANY
#define STM32_DAC_DAC1_CH2_DMA_STREAM STM32_DMA_STREAM_ID_ANY
* GPT driver system settings.
#define STM32_GPT_USE_TIM1 FALSE
#define STM32_GPT_USE_TIM2 FALSE
#define STM32_GPT_USE_TIM3 FALSE
#define STM32_GPT_USE_TIM4 FALSE
#define STM32_GPT_USE_TIM5 FALSE
#define STM32_GPT_USE_TIM6 FALSE
#define STM32_GPT_USE_TIM7 FALSE
#define STM32_GPT_USE_TIM8 FALSE
#define STM32_GPT_USE_TIM12 FALSE
#define STM32_GPT_USE_TIM13 FALSE
#define STM32_GPT_USE_TIM14 FALSE
#define STM32_GPT_USE_TIM15 FALSE
#define STM32_GPT_USE_TIM16 FALSE
#define STM32_GPT_USE_TIM17 FALSE
* I2C driver system settings.
#define STM32_I2C_USE_I2C1 FALSE
#define STM32_I2C_USE_I2C2 TRUE
#define STM32_I2C_USE_I2C3 FALSE
#define STM32_I2C_USE_I2C4 FALSE
#define STM32_I2C_BUSY_TIMEOUT 50
#define STM32_I2C_I2C1_RX_DMA_STREAM STM32_DMA_STREAM_ID_ANY
#define STM32_I2C_I2C1_TX_DMA_STREAM STM32_DMA_STREAM_ID_ANY
#define STM32_I2C_I2C2_RX_DMA_STREAM STM32_DMA_STREAM_ID_ANY
#define STM32_I2C_I2C2_TX_DMA_STREAM STM32_DMA_STREAM_ID_ANY
#define STM32_I2C_I2C3_RX_DMA_STREAM STM32_DMA_STREAM_ID_ANY
#define STM32_I2C_I2C3_TX_DMA_STREAM STM32_DMA_STREAM_ID_ANY
#define STM32_I2C_I2C4_RX_BDMA_STREAM STM32_BDMA_STREAM_ID_ANY
#define STM32_I2C_I2C4_TX_BDMA_STREAM STM32_BDMA_STREAM_ID_ANY
#define STM32_I2C_I2C1_IRQ_PRIORITY 5
#define STM32_I2C_I2C2_IRQ_PRIORITY 5
#define STM32_I2C_I2C3_IRQ_PRIORITY 5
#define STM32_I2C_I2C4_IRQ_PRIORITY 5
#define STM32_I2C_I2C1_DMA_PRIORITY 3
#define STM32_I2C_I2C2_DMA_PRIORITY 3
#define STM32_I2C_I2C3_DMA_PRIORITY 3
#define STM32_I2C_I2C4_DMA_PRIORITY 3
#define STM32_I2C_DMA_ERROR_HOOK(i2cp) osalSysHalt("DMA failure")
* ICU driver system settings.
#define STM32_ICU_USE_TIM1 FALSE
#define STM32_ICU_USE_TIM2 FALSE
#define STM32_ICU_USE_TIM3 FALSE
#define STM32_ICU_USE_TIM4 FALSE
#define STM32_ICU_USE_TIM5 FALSE
#define STM32_ICU_USE_TIM8 FALSE
#define STM32_ICU_USE_TIM12 FALSE
#define STM32_ICU_USE_TIM13 FALSE
#define STM32_ICU_USE_TIM14 FALSE
#define STM32_ICU_USE_TIM15 FALSE
#define STM32_ICU_USE_TIM16 FALSE
#define STM32_ICU_USE_TIM17 FALSE
* MAC driver system settings.
#define STM32_MAC_TRANSMIT_BUFFERS 2
#define STM32_MAC_RECEIVE_BUFFERS 4
#define STM32_MAC_BUFFERS_SIZE 1522
#define STM32_MAC_PHY_TIMEOUT 100
#define STM32_MAC_ETH1_CHANGE_PHY_STATE TRUE
#define STM32_MAC_ETH1_IRQ_PRIORITY 13
#define STM32_MAC_IP_CHECKSUM_OFFLOAD 0
* PWM driver system settings.
#define STM32_PWM_USE_TIM1 FALSE
#define STM32_PWM_USE_TIM2 FALSE
#define STM32_PWM_USE_TIM3 FALSE
#define STM32_PWM_USE_TIM4 FALSE
#define STM32_PWM_USE_TIM5 FALSE
#define STM32_PWM_USE_TIM8 FALSE
#define STM32_PWM_USE_TIM12 FALSE
#define STM32_PWM_USE_TIM13 FALSE
#define STM32_PWM_USE_TIM14 FALSE
#define STM32_PWM_USE_TIM15 FALSE
#define STM32_PWM_USE_TIM16 FALSE
#define STM32_PWM_USE_TIM17 FALSE
* RTC driver system settings.
#define STM32_RTC_PRESA_VALUE 32
#define STM32_RTC_PRESS_VALUE 1024
#define STM32_RTC_CR_INIT 0
#define STM32_RTC_TAMPCR_INIT 0
* SDC driver system settings.
#define STM32_SDC_USE_SDMMC1 TRUE
#define STM32_SDC_USE_SDMMC2 FALSE
#define STM32_SDC_SDMMC_UNALIGNED_SUPPORT TRUE
#define STM32_SDC_SDMMC_WRITE_TIMEOUT 10000
#define STM32_SDC_SDMMC_READ_TIMEOUT 10000
#define STM32_SDC_SDMMC_CLOCK_DELAY 10
#define STM32_SDC_SDMMC_PWRSAV TRUE
* SERIAL driver system settings.
#define STM32_SERIAL_USE_USART1 TRUE
#define STM32_SERIAL_USE_USART2 FALSE
#define STM32_SERIAL_USE_USART3 FALSE
#define STM32_SERIAL_USE_UART4 FALSE
#define STM32_SERIAL_USE_UART5 TRUE
#define STM32_SERIAL_USE_USART6 FALSE
#define STM32_SERIAL_USE_UART7 FALSE
#define STM32_SERIAL_USE_UART8 FALSE
#define STM32_SERIAL_USE_LPUART1 FALSE
* SIO driver system settings.
#define STM32_SIO_USE_USART1 FALSE
#define STM32_SIO_USE_USART2 FALSE
#define STM32_SIO_USE_USART3 FALSE
#define STM32_SIO_USE_UART4 FALSE
#define STM32_SIO_USE_UART5 FALSE
#define STM32_SIO_USE_USART6 FALSE
#define STM32_SIO_USE_UART7 FALSE
#define STM32_SIO_USE_UART8 FALSE
#define STM32_SIO_USE_LPUART1 FALSE
* SPI driver system settings.
#define STM32_SPI_USE_SPI1 TRUE
#define STM32_SPI_USE_SPI2 TRUE
#define STM32_SPI_USE_SPI3 TRUE
#define STM32_SPI_USE_SPI4 FALSE
#define STM32_SPI_USE_SPI5 TRUE
#define STM32_SPI_USE_SPI6 TRUE
#define STM32_SPI_SPI1_RX_DMA_STREAM STM32_DMA_STREAM_ID_ANY
#define STM32_SPI_SPI1_TX_DMA_STREAM STM32_DMA_STREAM_ID_ANY
#define STM32_SPI_SPI2_RX_DMA_STREAM STM32_DMA_STREAM_ID_ANY
#define STM32_SPI_SPI2_TX_DMA_STREAM STM32_DMA_STREAM_ID_ANY
#define STM32_SPI_SPI3_RX_DMA_STREAM STM32_DMA_STREAM_ID_ANY
#define STM32_SPI_SPI3_TX_DMA_STREAM STM32_DMA_STREAM_ID_ANY
#define STM32_SPI_SPI4_RX_DMA_STREAM STM32_DMA_STREAM_ID_ANY
#define STM32_SPI_SPI4_TX_DMA_STREAM STM32_DMA_STREAM_ID_ANY
#define STM32_SPI_SPI5_RX_DMA_STREAM STM32_DMA_STREAM_ID_ANY
#define STM32_SPI_SPI5_TX_DMA_STREAM STM32_DMA_STREAM_ID_ANY
#define STM32_SPI_SPI6_RX_BDMA_STREAM STM32_BDMA_STREAM_ID_ANY
#define STM32_SPI_SPI6_TX_BDMA_STREAM STM32_BDMA_STREAM_ID_ANY
#define STM32_SPI_SPI1_DMA_PRIORITY 1
#define STM32_SPI_SPI2_DMA_PRIORITY 1
#define STM32_SPI_SPI3_DMA_PRIORITY 1
#define STM32_SPI_SPI4_DMA_PRIORITY 1
#define STM32_SPI_SPI5_DMA_PRIORITY 1
#define STM32_SPI_SPI6_DMA_PRIORITY 1
#define STM32_SPI_SPI1_IRQ_PRIORITY 10
#define STM32_SPI_SPI2_IRQ_PRIORITY 10
#define STM32_SPI_SPI3_IRQ_PRIORITY 10
#define STM32_SPI_SPI4_IRQ_PRIORITY 10
#define STM32_SPI_SPI5_IRQ_PRIORITY 10
#define STM32_SPI_SPI6_IRQ_PRIORITY 10
#define STM32_SPI_DMA_ERROR_HOOK(spip) osalSysHalt("DMA failure")
* FMC/FSMC + SDRAM driver system settings (ChibiOS-Contrib).
#define STM32_FSMC_USE_FSMC1 TRUE
#define STM32_SDRAM_USE_SDRAM1 TRUE
#define STM32_SDRAM_USE_SDRAM2 FALSE
* ST driver system settings.
#define STM32_ST_IRQ_PRIORITY 8
#define STM32_ST_USE_TIMER 2
* TRNG driver system settings.
#define STM32_TRNG_USE_RNG1 FALSE
* UART driver system settings.
#define STM32_UART_USE_USART1 FALSE
#define STM32_UART_USE_USART2 FALSE
#define STM32_UART_USE_USART3 FALSE
#define STM32_UART_USE_UART4 FALSE
#define STM32_UART_USE_UART5 FALSE
#define STM32_UART_USE_USART6 FALSE
#define STM32_UART_USE_UART7 FALSE
#define STM32_UART_USE_UART8 FALSE
#define STM32_UART_USART1_RX_DMA_STREAM STM32_DMA_STREAM_ID_ANY
#define STM32_UART_USART1_TX_DMA_STREAM STM32_DMA_STREAM_ID_ANY
#define STM32_UART_USART2_RX_DMA_STREAM STM32_DMA_STREAM_ID_ANY
#define STM32_UART_USART2_TX_DMA_STREAM STM32_DMA_STREAM_ID_ANY
#define STM32_UART_USART3_RX_DMA_STREAM STM32_DMA_STREAM_ID_ANY
#define STM32_UART_USART3_TX_DMA_STREAM STM32_DMA_STREAM_ID_ANY
#define STM32_UART_UART4_RX_DMA_STREAM STM32_DMA_STREAM_ID_ANY
#define STM32_UART_UART4_TX_DMA_STREAM STM32_DMA_STREAM_ID_ANY
#define STM32_UART_UART5_RX_DMA_STREAM STM32_DMA_STREAM_ID_ANY
#define STM32_UART_UART5_TX_DMA_STREAM STM32_DMA_STREAM_ID_ANY
#define STM32_UART_USART6_RX_DMA_STREAM STM32_DMA_STREAM_ID_ANY
#define STM32_UART_USART6_TX_DMA_STREAM STM32_DMA_STREAM_ID_ANY
#define STM32_UART_UART7_RX_DMA_STREAM STM32_DMA_STREAM_ID_ANY
#define STM32_UART_UART7_TX_DMA_STREAM STM32_DMA_STREAM_ID_ANY
#define STM32_UART_UART8_RX_DMA_STREAM STM32_DMA_STREAM_ID_ANY
#define STM32_UART_UART8_TX_DMA_STREAM STM32_DMA_STREAM_ID_ANY
#define STM32_UART_USART1_DMA_PRIORITY 0
#define STM32_UART_USART2_DMA_PRIORITY 0
#define STM32_UART_USART3_DMA_PRIORITY 0
#define STM32_UART_UART4_DMA_PRIORITY 0
#define STM32_UART_UART5_DMA_PRIORITY 0
#define STM32_UART_USART6_DMA_PRIORITY 0
#define STM32_UART_UART7_DMA_PRIORITY 0
#define STM32_UART_UART8_DMA_PRIORITY 0
#define STM32_UART_DMA_ERROR_HOOK(uartp) osalSysHalt("DMA failure")
* USB driver system settings.
#define STM32_USB_USE_OTG1 TRUE
#define STM32_USB_USE_OTG2 FALSE
#define STM32_USB_OTG1_IRQ_PRIORITY 14
#define STM32_USB_OTG2_IRQ_PRIORITY 14
#define STM32_USB_OTG1_RX_FIFO_SIZE 512
#define STM32_USB_OTG2_RX_FIFO_SIZE 1024
#define STM32_USB_HOST_WAKEUP_DURATION 2
* WDG driver system settings.
#define STM32_WDG_USE_IWDG FALSE
* WSPI driver system settings.
#define STM32_WSPI_USE_QUADSPI1 FALSE
#define STM32_WSPI_QUADSPI1_PRESCALER_VALUE 1
#define STM32_WSPI_SET_CR_SSHIFT TRUE
#define STM32_WSPI_QUADSPI1_MDMA_CHANNEL STM32_MDMA_CHANNEL_ID_ANY
#define STM32_WSPI_QUADSPI1_MDMA_PRIORITY 1
#define STM32_WSPI_MDMA_ERROR_HOOK(wspip) osalSysHalt("MDMA failure")
#endif /* MCUCONF_H */
halconf.h
* @file templates/halconf.h
* @brief HAL configuration header.
* @details HAL configuration file, this file allows to enable or disable the
* various device drivers from your application. You may also use
* this file in order to override the device drivers default settings.
* @addtogroup HAL_CONF
#ifndef HALCONF_H
#define HALCONF_H
#define _CHIBIOS_HAL_CONF_
#define _CHIBIOS_HAL_CONF_VER_9_0_
#include "mcuconf.h"
* @brief Enables the community drivers subsystem.
#if !defined(HAL_USE_COMMUNITY) || defined(__DOXYGEN__)
#define HAL_USE_COMMUNITY TRUE
* @brief Enables the PAL subsystem.
#if !defined(HAL_USE_PAL) || defined(__DOXYGEN__)
#define HAL_USE_PAL TRUE
* @brief Enables the ADC subsystem.
#if !defined(HAL_USE_ADC) || defined(__DOXYGEN__)
#define HAL_USE_ADC TRUE
* @brief Enables the CAN subsystem.
#if !defined(HAL_USE_CAN) || defined(__DOXYGEN__)
#define HAL_USE_CAN FALSE
* @brief Enables the cryptographic subsystem.
#if !defined(HAL_USE_CRY) || defined(__DOXYGEN__)
#define HAL_USE_CRY FALSE
* @brief Enables the DAC subsystem.
#if !defined(HAL_USE_DAC) || defined(__DOXYGEN__)
#define HAL_USE_DAC FALSE
#define HAL_USE_SDRAM TRUE
#define HAL_USE_FSMC TRUE
* @brief Enables the EFlash subsystem.
#if !defined(HAL_USE_EFL) || defined(__DOXYGEN__)
#define HAL_USE_EFL FALSE
* @brief Enables the GPT subsystem.
#if !defined(HAL_USE_GPT) || defined(__DOXYGEN__)
#define HAL_USE_GPT FALSE
* @brief Enables the I2C subsystem.
#if !defined(HAL_USE_I2C) || defined(__DOXYGEN__)
#define HAL_USE_I2C TRUE
* @brief Enables the I2S subsystem.
#if !defined(HAL_USE_I2S) || defined(__DOXYGEN__)
#define HAL_USE_I2S FALSE
* @brief Enables the ICU subsystem.
#if !defined(HAL_USE_ICU) || defined(__DOXYGEN__)
#define HAL_USE_ICU FALSE
* @brief Enables the MAC subsystem.
#if !defined(HAL_USE_MAC) || defined(__DOXYGEN__)
#define HAL_USE_MAC FALSE
* @brief Enables the MMC_SPI subsystem.
#if !defined(HAL_USE_MMC_SPI) || defined(__DOXYGEN__)
#define HAL_USE_MMC_SPI FALSE
* @brief Enables the PWM subsystem.
#if !defined(HAL_USE_PWM) || defined(__DOXYGEN__)
#define HAL_USE_PWM FALSE
* @brief Enables the RTC subsystem.
#if !defined(HAL_USE_RTC) || defined(__DOXYGEN__)
#define HAL_USE_RTC FALSE
* @brief Enables the SDC subsystem.
#if !defined(HAL_USE_SDC) || defined(__DOXYGEN__)
#define HAL_USE_SDC TRUE
* @brief Enables the SERIAL subsystem.
#if !defined(HAL_USE_SERIAL) || defined(__DOXYGEN__)
#define HAL_USE_SERIAL TRUE
* @brief Enables the SERIAL over USB subsystem.
#if !defined(HAL_USE_SERIAL_USB) || defined(__DOXYGEN__)
#define HAL_USE_SERIAL_USB FALSE
* @brief Enables the SIO subsystem.
#if !defined(HAL_USE_SIO) || defined(__DOXYGEN__)
#define HAL_USE_SIO FALSE
* @brief Enables the SPI subsystem.
#if !defined(HAL_USE_SPI) || defined(__DOXYGEN__)
#define HAL_USE_SPI TRUE
* @brief Enables the TRNG subsystem.
#if !defined(HAL_USE_TRNG) || defined(__DOXYGEN__)
#define HAL_USE_TRNG FALSE
* @brief Enables the UART subsystem.
#if !defined(HAL_USE_UART) || defined(__DOXYGEN__)
#define HAL_USE_UART FALSE
* @brief Enables the USB subsystem.
#if !defined(HAL_USE_USB) || defined(__DOXYGEN__)
#define HAL_USE_USB TRUE
* @brief Enables the WDG subsystem.
#if !defined(HAL_USE_WDG) || defined(__DOXYGEN__)
#define HAL_USE_WDG FALSE
* @brief Enables the WSPI subsystem.
#if !defined(HAL_USE_WSPI) || defined(__DOXYGEN__)
#define HAL_USE_WSPI FALSE
/* PAL driver related settings. */
* @brief Enables synchronous APIs.
* @note Disabling this option saves both code and data space.
#if !defined(PAL_USE_CALLBACKS) || defined(__DOXYGEN__)
#define PAL_USE_CALLBACKS FALSE
#if !defined(PAL_USE_WAIT) || defined(__DOXYGEN__)
#define PAL_USE_WAIT FALSE
/* ADC driver related settings. */
#if !defined(ADC_USE_WAIT) || defined(__DOXYGEN__)
#define ADC_USE_WAIT TRUE
* @brief Enables the @p adcAcquireBus() and @p adcReleaseBus() APIs.
#if !defined(ADC_USE_MUTUAL_EXCLUSION) || defined(__DOXYGEN__)
#define ADC_USE_MUTUAL_EXCLUSION TRUE
/* CAN driver related settings. */
* @brief Sleep mode related APIs inclusion switch.
#if !defined(CAN_USE_SLEEP_MODE) || defined(__DOXYGEN__)
#define CAN_USE_SLEEP_MODE TRUE
* @brief Enforces the driver to use direct callbacks rather than OSAL events.
#if !defined(CAN_ENFORCE_USE_CALLBACKS) || defined(__DOXYGEN__)
#define CAN_ENFORCE_USE_CALLBACKS FALSE
/* CRY driver related settings. */
* @brief Enables the SW fall-back of the cryptographic driver.
* @details When enabled, this option, activates a fall-back software
* implementation for algorithms not supported by the underlying
* hardware.
* @note Fall-back implementations may not be present for all algorithms.
#if !defined(HAL_CRY_USE_FALLBACK) || defined(__DOXYGEN__)
#define HAL_CRY_USE_FALLBACK FALSE
* @brief Makes the driver forcibly use the fall-back implementations.
#if !defined(HAL_CRY_ENFORCE_FALLBACK) || defined(__DOXYGEN__)
#define HAL_CRY_ENFORCE_FALLBACK FALSE
/* DAC driver related settings. */
#if !defined(DAC_USE_WAIT) || defined(__DOXYGEN__)
#define DAC_USE_WAIT TRUE
* @brief Enables the @p dacAcquireBus() and @p dacReleaseBus() APIs.
#if !defined(DAC_USE_MUTUAL_EXCLUSION) || defined(__DOXYGEN__)
#define DAC_USE_MUTUAL_EXCLUSION TRUE
/* I2C driver related settings. */
* @brief Slave mode API enable switch.
* @note The low level driver must support this capability.
#if !defined(I2C_ENABLE_SLAVE_MODE)
#define I2C_ENABLE_SLAVE_MODE FALSE
* @brief Enables the mutual exclusion APIs on the I2C bus.
#if !defined(I2C_USE_MUTUAL_EXCLUSION) || defined(__DOXYGEN__)
#define I2C_USE_MUTUAL_EXCLUSION TRUE
/* MAC driver related settings. */
* @brief Enables the zero-copy API.
#if !defined(MAC_USE_ZERO_COPY) || defined(__DOXYGEN__)
#define MAC_USE_ZERO_COPY FALSE
* @brief Enables an event sources for incoming packets.
#if !defined(MAC_USE_EVENTS) || defined(__DOXYGEN__)
#define MAC_USE_EVENTS TRUE
/* MMC_SPI driver related settings. */
* @brief Timeout before assuming a failure while waiting for card idle.
* @note Time is in milliseconds.
#if !defined(MMC_IDLE_TIMEOUT_MS) || defined(__DOXYGEN__)
#define MMC_IDLE_TIMEOUT_MS 1000
* @brief Mutual exclusion on the SPI bus.
#if !defined(MMC_USE_MUTUAL_EXCLUSION) || defined(__DOXYGEN__)
#define MMC_USE_MUTUAL_EXCLUSION TRUE
/* SDC driver related settings. */
* @brief Number of initialization attempts before rejecting the card.
* @note Attempts are performed at 10mS intervals.
#if !defined(SDC_INIT_RETRY) || defined(__DOXYGEN__)
#define SDC_INIT_RETRY 100
* @brief Include support for MMC cards.
* @note MMC support is not yet implemented so this option must be kept
* at @p FALSE.
#if !defined(SDC_MMC_SUPPORT) || defined(__DOXYGEN__)
#define SDC_MMC_SUPPORT FALSE
* @brief Delays insertions.
* @details If enabled this options inserts delays into the MMC waiting
* routines releasing some extra CPU time for the threads with
* lower priority, this may slow down the driver a bit however.
#if !defined(SDC_NICE_WAITING) || defined(__DOXYGEN__)
#define SDC_NICE_WAITING TRUE
* @brief OCR initialization constant for V20 cards.
#if !defined(SDC_INIT_OCR_V20) || defined(__DOXYGEN__)
#define SDC_INIT_OCR_V20 0x50FF8000U
* @brief OCR initialization constant for non-V20 cards.
#if !defined(SDC_INIT_OCR) || defined(__DOXYGEN__)
#define SDC_INIT_OCR 0x80100000U
/* SERIAL driver related settings. */
* @brief Default bit rate.
* @details Configuration parameter, this is the baud rate selected for the
* default configuration.
#if !defined(SERIAL_DEFAULT_BITRATE) || defined(__DOXYGEN__)
#define SERIAL_DEFAULT_BITRATE 38400
* @brief Serial buffers size.
* @details Configuration parameter, you can change the depth of the queue
* buffers depending on the requirements of your application.
* @note The default is 16 bytes for both the transmission and receive
* buffers.
#if !defined(SERIAL_BUFFERS_SIZE) || defined(__DOXYGEN__)
#define SERIAL_BUFFERS_SIZE 16
/* SIO driver related settings. */
#if !defined(SIO_DEFAULT_BITRATE) || defined(__DOXYGEN__)
#define SIO_DEFAULT_BITRATE 38400
* @brief Support for thread synchronization API.
#if !defined(SIO_USE_SYNCHRONIZATION) || defined(__DOXYGEN__)
#define SIO_USE_SYNCHRONIZATION TRUE
/* SERIAL_USB driver related setting. */
* @brief Serial over USB buffers size.
* @details Configuration parameter, the buffer size must be a multiple of
* the USB data endpoint maximum packet size.
* @note The default is 256 bytes for both the transmission and receive
* buffers.
#if !defined(SERIAL_USB_BUFFERS_SIZE) || defined(__DOXYGEN__)
#define SERIAL_USB_BUFFERS_SIZE 256
* @brief Serial over USB number of buffers.
* @note The default is 2 buffers.
#if !defined(SERIAL_USB_BUFFERS_NUMBER) || defined(__DOXYGEN__)
#define SERIAL_USB_BUFFERS_NUMBER 2
/* SPI driver related settings. */
#if !defined(SPI_USE_WAIT) || defined(__DOXYGEN__)
#define SPI_USE_WAIT TRUE
* @brief Inserts an assertion on function errors before returning.
#if !defined(SPI_USE_ASSERT_ON_ERROR) || defined(__DOXYGEN__)
#define SPI_USE_ASSERT_ON_ERROR TRUE
* @brief Enables the @p spiAcquireBus() and @p spiReleaseBus() APIs.
#if !defined(SPI_USE_MUTUAL_EXCLUSION) || defined(__DOXYGEN__)
#define SPI_USE_MUTUAL_EXCLUSION TRUE
* @brief Handling method for SPI CS line.
#if !defined(SPI_SELECT_MODE) || defined(__DOXYGEN__)
#define SPI_SELECT_MODE SPI_SELECT_MODE_PAD
/* UART driver related settings. */
#if !defined(UART_USE_WAIT) || defined(__DOXYGEN__)
#define UART_USE_WAIT FALSE
* @brief Enables the @p uartAcquireBus() and @p uartReleaseBus() APIs.
#if !defined(UART_USE_MUTUAL_EXCLUSION) || defined(__DOXYGEN__)
#define UART_USE_MUTUAL_EXCLUSION FALSE
/* USB driver related settings. */
#if !defined(USB_USE_WAIT) || defined(__DOXYGEN__)
#define USB_USE_WAIT FALSE
/* WSPI driver related settings. */
#if !defined(WSPI_USE_WAIT) || defined(__DOXYGEN__)
#define WSPI_USE_WAIT TRUE
* @brief Enables the @p wspiAcquireBus() and @p wspiReleaseBus() APIs.
#if !defined(WSPI_USE_MUTUAL_EXCLUSION) || defined(__DOXYGEN__)
#define WSPI_USE_MUTUAL_EXCLUSION TRUE
#if !defined(HAL_USE_FSMC) || defined(__DOXYGEN__)
#endif /* HALCONF_H */
board.h
/* ===================== SDMMC1 PIN MAPPING ===================== */
/* PC8 = SDMMC1_D0 */
/* PC9 = SDMMC1_D1 */
/* PC10 = SDMMC1_D2 */
/* PC11 = SDMMC1_D3 */
/* PC12 = SDMMC1_CK */
/* PD2 = SDMMC1_CMD */
#define GPIOC_SDMMC1_D0 8U
#define GPIOC_SDMMC1_D1 9U
#define GPIOC_SDMMC1_D2 10U
#define GPIOC_SDMMC1_D3 11U
#define GPIOC_SDMMC1_CK 12U
#define GPIOD_SDMMC1_CMD 2U
/* GPIOC config */
#define VAL_GPIOC_MODER ( \
PIN_MODE_ALTERNATE(GPIOC_SDMMC1_D0) | \
PIN_MODE_ALTERNATE(GPIOC_SDMMC1_D1) | \
PIN_MODE_ALTERNATE(GPIOC_SDMMC1_D2) | \
PIN_MODE_ALTERNATE(GPIOC_SDMMC1_D3) | \
PIN_MODE_ALTERNATE(GPIOC_SDMMC1_CK) )
#define VAL_GPIOC_OTYPER ( \
PIN_OTYPE_PUSHPULL(GPIOC_SDMMC1_D0) | \
PIN_OTYPE_PUSHPULL(GPIOC_SDMMC1_D1) | \
PIN_OTYPE_PUSHPULL(GPIOC_SDMMC1_D2) | \
PIN_OTYPE_PUSHPULL(GPIOC_SDMMC1_D3) | \
PIN_OTYPE_PUSHPULL(GPIOC_SDMMC1_CK) )
#define VAL_GPIOC_OSPEEDR ( \
PIN_OSPEED_HIGH(GPIOC_SDMMC1_D0) | \
PIN_OSPEED_HIGH(GPIOC_SDMMC1_D1) | \
PIN_OSPEED_HIGH(GPIOC_SDMMC1_D2) | \
PIN_OSPEED_HIGH(GPIOC_SDMMC1_D3) | \
PIN_OSPEED_HIGH(GPIOC_SDMMC1_CK) )
#define VAL_GPIOC_PUPDR ( \
PIN_PUPDR_PULLUP(GPIOC_SDMMC1_D0) | \
PIN_PUPDR_PULLUP(GPIOC_SDMMC1_D1) | \
PIN_PUPDR_PULLUP(GPIOC_SDMMC1_D2) | \
PIN_PUPDR_PULLUP(GPIOC_SDMMC1_D3) | \
PIN_PUPDR_FLOATING(GPIOC_SDMMC1_CK) )
#define VAL_GPIOC_AFRH ( \
PIN_AFIO_AF(GPIOC_SDMMC1_D0, 12U) | \
PIN_AFIO_AF(GPIOC_SDMMC1_D1, 12U) | \
PIN_AFIO_AF(GPIOC_SDMMC1_D2, 12U) | \
PIN_AFIO_AF(GPIOC_SDMMC1_D3, 12U) | \
PIN_AFIO_AF(GPIOC_SDMMC1_CK, 12U) )
/* GPIOD config */
#define VAL_GPIOD_MODER PIN_MODE_ALTERNATE(GPIOD_SDMMC1_CMD)
#define VAL_GPIOD_OTYPER PIN_OTYPE_PUSHPULL(GPIOD_SDMMC1_CMD)
#define VAL_GPIOD_OSPEEDR PIN_OSPEED_HIGH(GPIOD_SDMMC1_CMD)
#define VAL_GPIOD_PUPDR PIN_PUPDR_PULLUP(GPIOD_SDMMC1_CMD)
#define VAL_GPIOD_AFRL PIN_AFIO_AF(GPIOD_SDMMC1_CMD, 12U)
Any help would be greatly appreciated.
Thank you very much.
