STM32H743 SDMMC1 completely dead (no clock, no flags) on STM32H743
Louwik
Post by Louwik »
I am trying to bring up SDMMC1 on an STM32H743 using ChibiOS 21.11.4 and I am completely stuck.
The same board and the same SD card work perfectly with STM32Cube HAL.
With ChibiOS, the SDMMC peripheral appears to be electrically dead.
- Symptoms:
* SDMMC1 registers are accessible and writable
* AHB3 clock is enabled (`RCC->AHB3ENR` SDMMC1EN bit is set)
* SDMMC kernel clock source is configured (tested both PLL1Q and PLL2R)
* PLLs are running and stable
* `SDMMC->POWER = 0x3`
* `SDMMC->CLKCR` is programmed (e.g. `0x164`, CLKEN = 1)
But:
* `SDMMC->STA` always remains `0x00000000`
* No flags ever appear: no `CMDSENT`, no `CMDREND`, no `CTIMEOUT`, no errors
* Sending CMD0 or any command manually does nothing
* `sdcConnect()` always fails
* Even with no card inserted, there is absolutely no activity
The SDMMC behaves as if the whole peripheral block is not clocked or not powered.
- What I verified in GDB:
* `RCC->AHB3ENR` SDMMC1 bit is set
* `RCC->D1CCIPR` is correctly configured for SDMMC kernel clock
* `RCC->PLL1CR` / `RCC->PLL2CR` show PLLs enabled and stable
* The SDMMC registers can be written and read back correctly
* `SDMMC->CLKCR` has CLKEN = 1
* `SDMMC->POWER = 3`
Yet:
* `SDMMC->STA` stays at 0 forever
- What I tried
* Forcing SDMMC clocks manually in code and in GDB
* Forcing SDMMC kernel clock source (PLL1Q, PLL2R)
* Forcing SDMMC registers manually
* Using both ChibiOS SDC driver and raw register access
* Testing on several different boards (same result)
* Comparing with STM32Cube HAL project (works perfectly there)
- Question:
On STM32H743:
Is there any additional power-domain / PWR / VDDMMC / CR3 / SMPS / LDO / domain enable needed to actually power the SDMMC1 block?
Is there anything specific that ChibiOS does (or does not do) regarding SDMMC power or clock domain enable on H7?
Is there any known missing step or bug in ChibiOS 21.11.x for SDMMC on H7?
And more generally:
Is there something obvious that I might be missing in the STM32H7 SDMMC bring-up sequence?
At this point the peripheral behaves exactly as if the SDMMC block is electrically OFF.
Here are the relevant files from my project:
main.c
#include "ch.h"
#include "hal.h"
#include "chprintf.h"
static SerialConfig sercfg = {
  115200,
  0,
  USART_CR2_STOP1_BITS,
  0
int main(void) {
  sdStart(&SD1, &sercfg);
  chprintf((BaseSequentialStream *)&SD1, "\r\n=== STM32H743 SDMMC MINIMAL TEST ===\r\n");
  chprintf((BaseSequentialStream *)&SD1, "Starting SDC...\r\n");
  sdcStart(&SDCD1, NULL);
  chprintf((BaseSequentialStream *)&SD1, "Connecting to card...\r\n");
  if (sdcConnect(&SDCD1)) {
    chprintf((BaseSequentialStream *)&SD1, "ERROR: sdcConnect failed\r\n");
    chprintf((BaseSequentialStream *)&SD1, "SDMMC_STA   = 0x%08X\r\n", *((volatile uint32_t*)0x52007034));
    chprintf((BaseSequentialStream *)&SD1, "SDMMC_CLKCR = 0x%08X\r\n", *((volatile uint32_t*)0x52007004));
    chprintf((BaseSequentialStream *)&SD1, "SDMMC_POWER = 0x%08X\r\n", *((volatile uint32_t*)0x52007000));
    while (true) {
      chThdSleepMilliseconds(1000);
  chprintf((BaseSequentialStream *)&SD1, "SD card detected successfully.\r\n");
  while (true) {
mcuconf.h
    ChibiOS - Copyright (C) 2006..2025 Giovanni Di Sirio
#ifndef MCUCONF_H
#define MCUCONF_H
 * STM32H7xx drivers configuration.
 * The following settings override the default settings present in
 * the various device driver implementation headers.
 * Note that the settings for each driver only have effect if the whole
 * driver is enabled in halconf.h.
 * IRQ priorities:
 * 15...0       Lowest...Highest.
 * DMA priorities:
 * 0...3        Lowest...Highest.
#define STM32H7xx_MCUCONF
#define STM32H743_MCUCONF
 * General settings.
#define STM32_TARGET_CORE                   1
 * Memory attributes settings.
#define STM32_NOCACHE_ENABLE                FALSE
#define STM32_NOCACHE_MPU_REGION            MPU_REGION_6
#define STM32_NOCACHE_RBAR                  0x24000000U
#define STM32_NOCACHE_RASR                  MPU_RASR_SIZE_16K
 * PWR system settings.
 * Reading STM32 Reference Manual is required, settings in PWR_CR3 are
 * very critical.
 * Register constants are taken from the ST header.
#define STM32_VOS                           STM32_VOS_SCALE1
#define STM32_PWR_CR1                       (PWR_CR1_SVOS_1 | PWR_CR1_SVOS_0)
#define STM32_PWR_CR2                       (PWR_CR2_BREN)
#define STM32_PWR_CR3                       (PWR_CR3_LDOEN | PWR_CR3_USB33DEN)
#define STM32_PWR_CPUCR                     0
 * Clock tree static settings.
 * Reading STM32 Reference Manual is required.
#define STM32_LSI_ENABLED                   FALSE
#define STM32_CSI_ENABLED                   FALSE
#define STM32_HSI48_ENABLED                 TRUE
#define STM32_HSIDIV                        STM32_HSIDIV_DIV1
 * PLLs static settings.
#define STM32_PLLSRC                        STM32_PLLSRC_HSE_CK
#define STM32_PLLCFGR_MASK                  ~0
#define STM32_PLL1_ENABLED                  TRUE
#define STM32_PLL1_P_ENABLED                TRUE
#define STM32_PLL1_Q_ENABLED                TRUE
#define STM32_PLL1_R_ENABLED                TRUE
#define STM32_PLL1_DIVM_VALUE               5
#define STM32_PLL1_DIVN_VALUE               160
#define STM32_PLL1_FRACN_VALUE              0
#define STM32_PLL1_DIVP_VALUE               2
#define STM32_PLL1_DIVQ_VALUE               10
#define STM32_PLL1_DIVR_VALUE               2
#define STM32_PLL2_ENABLED                  TRUE
#define STM32_PLL2_P_ENABLED                TRUE
#define STM32_PLL2_Q_ENABLED                TRUE
#define STM32_PLL2_R_ENABLED                TRUE
#define STM32_PLL2_DIVM_VALUE               5
#define STM32_PLL2_DIVN_VALUE               98
#define STM32_PLL2_FRACN_VALUE              2494
#define STM32_PLL2_DIVP_VALUE               10
#define STM32_PLL2_DIVQ_VALUE               2
#define STM32_PLL2_DIVR_VALUE               12
#define STM32_PLL3_ENABLED                  TRUE
#define STM32_PLL3_P_ENABLED                TRUE
#define STM32_PLL3_Q_ENABLED                FALSE
#define STM32_PLL3_R_ENABLED                TRUE
#define STM32_PLL3_DIVM_VALUE               25
#define STM32_PLL3_DIVN_VALUE               288
#define STM32_PLL3_FRACN_VALUE              0
#define STM32_PLL3_DIVP_VALUE               4
#define STM32_PLL3_DIVQ_VALUE               6
#define STM32_PLL3_DIVR_VALUE               8
 * Core clocks dynamic settings (can be changed at runtime).
#define STM32_SW                            STM32_SW_PLL1_P_CK
#define STM32_RTCSEL                        STM32_RTCSEL_LSI_CK
#define STM32_D1CPRE                        STM32_D1CPRE_DIV1
#define STM32_D1HPRE                        STM32_D1HPRE_DIV2
#define STM32_D1PPRE3                       STM32_D1PPRE3_DIV2
#define STM32_D2PPRE1                       STM32_D2PPRE1_DIV2
#define STM32_D2PPRE2                       STM32_D2PPRE2_DIV2
#define STM32_D3PPRE4                       STM32_D3PPRE4_DIV2
 * Peripherals clocks static settings.
#define STM32_MCO1SEL                       STM32_MCO1SEL_HSI_CK
#define STM32_MCO1PRE_VALUE                 4
#define STM32_MCO2SEL                       STM32_MCO2SEL_SYS_CK
#define STM32_MCO2PRE_VALUE                 4
#define STM32_TIMPRE_ENABLE                 TRUE
#define STM32_HRTIMSEL                      0
#define STM32_STOPKERWUCK                   0
#define STM32_STOPWUCK                      0
#define STM32_RTCPRE_VALUE                  8
#define STM32_CKPERSEL                      STM32_CKPERSEL_HSI_CK
#define STM32_SDMMCSEL                      STM32_SDMMCSEL_PLL1_Q_CK
#define STM32_QSPISEL                       STM32_QSPISEL_HCLK
#define STM32_FMCSEL                        STM32_FMCSEL_HCLK
#define STM32_SWPSEL                        STM32_SWPSEL_PCLK1
#define STM32_FDCANSEL                      STM32_FDCANSEL_PLL1_Q_CK
#define STM32_DFSDM1SEL                     STM32_DFSDM1SEL_PCLK2
#define STM32_SPDIFSEL                      STM32_SPDIFSEL_PLL1_Q_CK
#define STM32_SPI45SEL                      STM32_SPI45SEL_PCLK2
#define STM32_SPI123SEL                     STM32_SPI123SEL_PLL1_Q_CK
#define STM32_SAI23SEL                      STM32_SAI23SEL_PLL2_P_CK
#define STM32_SAI1SEL                       STM32_SAI1SEL_PLL1_Q_CK
#define STM32_LPTIM1SEL                     STM32_LPTIM1SEL_PCLK1
#define STM32_CECSEL                        STM32_CECSEL_LSI_CK
#define STM32_USBSEL                        STM32_USBSEL_HSI48_CK
#define STM32_I2C123SEL                     STM32_I2C123SEL_PCLK1
#define STM32_RNGSEL                        STM32_RNGSEL_HSI48_CK
#define STM32_USART16SEL                    STM32_USART16SEL_PCLK2
#define STM32_USART234578SEL                STM32_USART234578SEL_PCLK1
#define STM32_SPI6SEL                       STM32_SPI6SEL_PCLK4
#define STM32_SAI4BSEL                      STM32_SAI4BSEL_PLL1_Q_CK
#define STM32_SAI4ASEL                      STM32_SAI4ASEL_PLL1_Q_CK
#define STM32_ADCSEL                        STM32_ADCSEL_DISABLE
#define STM32_LPTIM345SEL                   STM32_LPTIM345SEL_PCLK4
#define STM32_LPTIM2SEL                     STM32_LPTIM2SEL_PCLK4
#define STM32_I2C4SEL                       STM32_I2C4SEL_PCLK4
#define STM32_LPUART1SEL                    STM32_LPUART1SEL_PCLK4
 * IRQ system settings.
#define STM32_IRQ_EXTI0_PRIORITY            6
#define STM32_IRQ_EXTI1_PRIORITY            6
#define STM32_IRQ_EXTI2_PRIORITY            6
#define STM32_IRQ_EXTI3_PRIORITY            6
#define STM32_IRQ_EXTI4_PRIORITY            6
#define STM32_IRQ_EXTI5_9_PRIORITY          6
#define STM32_IRQ_EXTI10_15_PRIORITY        6
#define STM32_IRQ_EXTI16_PRIORITY           6
#define STM32_IRQ_EXTI17_PRIORITY           6
#define STM32_IRQ_EXTI18_PRIORITY           6
#define STM32_IRQ_EXTI19_PRIORITY           6
#define STM32_IRQ_EXTI20_21_PRIORITY        6
#define STM32_IRQ_FDCAN1_PRIORITY           10
#define STM32_IRQ_FDCAN2_PRIORITY           10
#define STM32_IRQ_MDMA_PRIORITY             9
#define STM32_IRQ_QUADSPI1_PRIORITY         10
#define STM32_IRQ_SDMMC1_PRIORITY           9
#define STM32_IRQ_SDMMC2_PRIORITY           9
#define STM32_IRQ_TIM1_UP_PRIORITY          7
#define STM32_IRQ_TIM1_CC_PRIORITY          7
#define STM32_IRQ_TIM2_PRIORITY             7
#define STM32_IRQ_TIM3_PRIORITY             7
#define STM32_IRQ_TIM4_PRIORITY             7
#define STM32_IRQ_TIM5_PRIORITY             7
#define STM32_IRQ_TIM6_PRIORITY             7
#define STM32_IRQ_TIM7_PRIORITY             7
#define STM32_IRQ_TIM8_BRK_TIM12_PRIORITY   7
#define STM32_IRQ_TIM8_UP_TIM13_PRIORITY    7
#define STM32_IRQ_TIM8_TRGCO_TIM14_PRIORITY 7
#define STM32_IRQ_TIM8_CC_PRIORITY          7
#define STM32_IRQ_TIM15_PRIORITY            7
#define STM32_IRQ_TIM16_PRIORITY            7
#define STM32_IRQ_TIM17_PRIORITY            7
#define STM32_IRQ_USART1_PRIORITY           12
#define STM32_IRQ_USART2_PRIORITY           12
#define STM32_IRQ_USART3_PRIORITY           12
#define STM32_IRQ_UART4_PRIORITY            12
#define STM32_IRQ_UART5_PRIORITY            12
#define STM32_IRQ_USART6_PRIORITY           12
#define STM32_IRQ_UART7_PRIORITY            12
#define STM32_IRQ_UART8_PRIORITY            12
#define STM32_IRQ_LPUART1_PRIORITY          12
 * ADC driver system settings.
#define STM32_ADC_DUAL_MODE                 FALSE
#define STM32_ADC_SAMPLES_SIZE              16
#define STM32_ADC_USE_ADC12                 TRUE
#define STM32_ADC_USE_ADC3                  FALSE
#define STM32_ADC_ADC12_DMA_STREAM          STM32_DMA_STREAM_ID_ANY
#define STM32_ADC_ADC3_DMA_STREAM           STM32_DMA_STREAM_ID_ANY
#define STM32_ADC_ADC3_USE_BDMA             FALSE
#define STM32_ADC_ADC3_BDMA_STREAM          STM32_BDMA_STREAM_ID_ANY
#define STM32_ADC_ADC12_DMA_PRIORITY        2
#define STM32_ADC_ADC3_DMA_PRIORITY         2
#define STM32_ADC_ADC12_IRQ_PRIORITY        5
#define STM32_ADC_ADC3_IRQ_PRIORITY         5
#define STM32_ADC_ADC12_CLOCK_MODE          ADC_CCR_CKMODE_ADCCK
#define STM32_ADC_ADC3_CLOCK_MODE           ADC_CCR_CKMODE_ADCCK
 * CAN driver system settings.
#define STM32_CAN_USE_FDCAN1                FALSE
#define STM32_CAN_USE_FDCAN2                FALSE
 * DAC driver system settings.
#define STM32_DAC_DUAL_MODE                 FALSE
#define STM32_DAC_USE_DAC1_CH1              FALSE
#define STM32_DAC_USE_DAC1_CH2              FALSE
#define STM32_DAC_DAC1_CH1_IRQ_PRIORITY     10
#define STM32_DAC_DAC1_CH2_IRQ_PRIORITY     10
#define STM32_DAC_DAC1_CH1_DMA_PRIORITY     2
#define STM32_DAC_DAC1_CH2_DMA_PRIORITY     2
#define STM32_DAC_DAC1_CH1_DMA_STREAM       STM32_DMA_STREAM_ID_ANY
#define STM32_DAC_DAC1_CH2_DMA_STREAM       STM32_DMA_STREAM_ID_ANY
 * GPT driver system settings.
#define STM32_GPT_USE_TIM1                  FALSE
#define STM32_GPT_USE_TIM2                  FALSE
#define STM32_GPT_USE_TIM3                  FALSE
#define STM32_GPT_USE_TIM4                  FALSE
#define STM32_GPT_USE_TIM5                  FALSE
#define STM32_GPT_USE_TIM6                  FALSE
#define STM32_GPT_USE_TIM7                  FALSE
#define STM32_GPT_USE_TIM8                  FALSE
#define STM32_GPT_USE_TIM12                 FALSE
#define STM32_GPT_USE_TIM13                 FALSE
#define STM32_GPT_USE_TIM14                 FALSE
#define STM32_GPT_USE_TIM15                 FALSE
#define STM32_GPT_USE_TIM16                 FALSE
#define STM32_GPT_USE_TIM17                 FALSE
 * I2C driver system settings.
#define STM32_I2C_USE_I2C1                  FALSE
#define STM32_I2C_USE_I2C2                  TRUE
#define STM32_I2C_USE_I2C3                  FALSE
#define STM32_I2C_USE_I2C4                  FALSE
#define STM32_I2C_BUSY_TIMEOUT              50
#define STM32_I2C_I2C1_RX_DMA_STREAM        STM32_DMA_STREAM_ID_ANY
#define STM32_I2C_I2C1_TX_DMA_STREAM        STM32_DMA_STREAM_ID_ANY
#define STM32_I2C_I2C2_RX_DMA_STREAM        STM32_DMA_STREAM_ID_ANY
#define STM32_I2C_I2C2_TX_DMA_STREAM        STM32_DMA_STREAM_ID_ANY
#define STM32_I2C_I2C3_RX_DMA_STREAM        STM32_DMA_STREAM_ID_ANY
#define STM32_I2C_I2C3_TX_DMA_STREAM        STM32_DMA_STREAM_ID_ANY
#define STM32_I2C_I2C4_RX_BDMA_STREAM       STM32_BDMA_STREAM_ID_ANY
#define STM32_I2C_I2C4_TX_BDMA_STREAM       STM32_BDMA_STREAM_ID_ANY
#define STM32_I2C_I2C1_IRQ_PRIORITY         5
#define STM32_I2C_I2C2_IRQ_PRIORITY         5
#define STM32_I2C_I2C3_IRQ_PRIORITY         5
#define STM32_I2C_I2C4_IRQ_PRIORITY         5
#define STM32_I2C_I2C1_DMA_PRIORITY         3
#define STM32_I2C_I2C2_DMA_PRIORITY         3
#define STM32_I2C_I2C3_DMA_PRIORITY         3
#define STM32_I2C_I2C4_DMA_PRIORITY         3
#define STM32_I2C_DMA_ERROR_HOOK(i2cp)      osalSysHalt("DMA failure")
 * ICU driver system settings.
#define STM32_ICU_USE_TIM1                  FALSE
#define STM32_ICU_USE_TIM2                  FALSE
#define STM32_ICU_USE_TIM3                  FALSE
#define STM32_ICU_USE_TIM4                  FALSE
#define STM32_ICU_USE_TIM5                  FALSE
#define STM32_ICU_USE_TIM8                  FALSE
#define STM32_ICU_USE_TIM12                 FALSE
#define STM32_ICU_USE_TIM13                 FALSE
#define STM32_ICU_USE_TIM14                 FALSE
#define STM32_ICU_USE_TIM15                 FALSE
#define STM32_ICU_USE_TIM16                 FALSE
#define STM32_ICU_USE_TIM17                 FALSE
 * MAC driver system settings.
#define STM32_MAC_TRANSMIT_BUFFERS          2
#define STM32_MAC_RECEIVE_BUFFERS           4
#define STM32_MAC_BUFFERS_SIZE              1522
#define STM32_MAC_PHY_TIMEOUT               100
#define STM32_MAC_ETH1_CHANGE_PHY_STATE     TRUE
#define STM32_MAC_ETH1_IRQ_PRIORITY         13
#define STM32_MAC_IP_CHECKSUM_OFFLOAD       0
 * PWM driver system settings.
#define STM32_PWM_USE_TIM1                  FALSE
#define STM32_PWM_USE_TIM2                  FALSE
#define STM32_PWM_USE_TIM3                  FALSE
#define STM32_PWM_USE_TIM4                  FALSE
#define STM32_PWM_USE_TIM5                  FALSE
#define STM32_PWM_USE_TIM8                  FALSE
#define STM32_PWM_USE_TIM12                 FALSE
#define STM32_PWM_USE_TIM13                 FALSE
#define STM32_PWM_USE_TIM14                 FALSE
#define STM32_PWM_USE_TIM15                 FALSE
#define STM32_PWM_USE_TIM16                 FALSE
#define STM32_PWM_USE_TIM17                 FALSE
 * RTC driver system settings.
#define STM32_RTC_PRESA_VALUE               32
#define STM32_RTC_PRESS_VALUE               1024
#define STM32_RTC_CR_INIT                   0
#define STM32_RTC_TAMPCR_INIT               0
 * SDC driver system settings.
#define STM32_SDC_USE_SDMMC1                TRUE
#define STM32_SDC_USE_SDMMC2                FALSE
#define STM32_SDC_SDMMC_UNALIGNED_SUPPORT   TRUE
#define STM32_SDC_SDMMC_WRITE_TIMEOUT       10000
#define STM32_SDC_SDMMC_READ_TIMEOUT        10000
#define STM32_SDC_SDMMC_CLOCK_DELAY         10
#define STM32_SDC_SDMMC_PWRSAV              TRUE
 * SERIAL driver system settings.
#define STM32_SERIAL_USE_USART1             TRUE
#define STM32_SERIAL_USE_USART2             FALSE
#define STM32_SERIAL_USE_USART3             FALSE
#define STM32_SERIAL_USE_UART4              FALSE
#define STM32_SERIAL_USE_UART5              TRUE
#define STM32_SERIAL_USE_USART6             FALSE
#define STM32_SERIAL_USE_UART7              FALSE
#define STM32_SERIAL_USE_UART8              FALSE
#define STM32_SERIAL_USE_LPUART1            FALSE
 * SIO driver system settings.
#define STM32_SIO_USE_USART1                FALSE
#define STM32_SIO_USE_USART2                FALSE
#define STM32_SIO_USE_USART3                FALSE
#define STM32_SIO_USE_UART4                 FALSE
#define STM32_SIO_USE_UART5                 FALSE
#define STM32_SIO_USE_USART6                FALSE
#define STM32_SIO_USE_UART7                 FALSE
#define STM32_SIO_USE_UART8                 FALSE
#define STM32_SIO_USE_LPUART1               FALSE
 * SPI driver system settings.
#define STM32_SPI_USE_SPI1                  TRUE
#define STM32_SPI_USE_SPI2                  TRUE
#define STM32_SPI_USE_SPI3                  TRUE
#define STM32_SPI_USE_SPI4                  FALSE
#define STM32_SPI_USE_SPI5                  TRUE
#define STM32_SPI_USE_SPI6                  TRUE
#define STM32_SPI_SPI1_RX_DMA_STREAM        STM32_DMA_STREAM_ID_ANY
#define STM32_SPI_SPI1_TX_DMA_STREAM        STM32_DMA_STREAM_ID_ANY
#define STM32_SPI_SPI2_RX_DMA_STREAM        STM32_DMA_STREAM_ID_ANY
#define STM32_SPI_SPI2_TX_DMA_STREAM        STM32_DMA_STREAM_ID_ANY
#define STM32_SPI_SPI3_RX_DMA_STREAM        STM32_DMA_STREAM_ID_ANY
#define STM32_SPI_SPI3_TX_DMA_STREAM        STM32_DMA_STREAM_ID_ANY
#define STM32_SPI_SPI4_RX_DMA_STREAM        STM32_DMA_STREAM_ID_ANY
#define STM32_SPI_SPI4_TX_DMA_STREAM        STM32_DMA_STREAM_ID_ANY
#define STM32_SPI_SPI5_RX_DMA_STREAM        STM32_DMA_STREAM_ID_ANY
#define STM32_SPI_SPI5_TX_DMA_STREAM        STM32_DMA_STREAM_ID_ANY
#define STM32_SPI_SPI6_RX_BDMA_STREAM       STM32_BDMA_STREAM_ID_ANY
#define STM32_SPI_SPI6_TX_BDMA_STREAM       STM32_BDMA_STREAM_ID_ANY
#define STM32_SPI_SPI1_DMA_PRIORITY         1
#define STM32_SPI_SPI2_DMA_PRIORITY         1
#define STM32_SPI_SPI3_DMA_PRIORITY         1
#define STM32_SPI_SPI4_DMA_PRIORITY         1
#define STM32_SPI_SPI5_DMA_PRIORITY         1
#define STM32_SPI_SPI6_DMA_PRIORITY         1
#define STM32_SPI_SPI1_IRQ_PRIORITY         10
#define STM32_SPI_SPI2_IRQ_PRIORITY         10
#define STM32_SPI_SPI3_IRQ_PRIORITY         10
#define STM32_SPI_SPI4_IRQ_PRIORITY         10
#define STM32_SPI_SPI5_IRQ_PRIORITY         10
#define STM32_SPI_SPI6_IRQ_PRIORITY         10
#define STM32_SPI_DMA_ERROR_HOOK(spip)      osalSysHalt("DMA failure")
 * FMC/FSMC + SDRAM driver system settings (ChibiOS-Contrib).
#define STM32_FSMC_USE_FSMC1               TRUE
#define STM32_SDRAM_USE_SDRAM1             TRUE
#define STM32_SDRAM_USE_SDRAM2             FALSE
 * ST driver system settings.
#define STM32_ST_IRQ_PRIORITY               8
#define STM32_ST_USE_TIMER                  2
 * TRNG driver system settings.
#define STM32_TRNG_USE_RNG1                 FALSE
 * UART driver system settings.
#define STM32_UART_USE_USART1               FALSE
#define STM32_UART_USE_USART2               FALSE
#define STM32_UART_USE_USART3               FALSE
#define STM32_UART_USE_UART4                FALSE
#define STM32_UART_USE_UART5                FALSE
#define STM32_UART_USE_USART6               FALSE
#define STM32_UART_USE_UART7                FALSE
#define STM32_UART_USE_UART8                FALSE
#define STM32_UART_USART1_RX_DMA_STREAM     STM32_DMA_STREAM_ID_ANY
#define STM32_UART_USART1_TX_DMA_STREAM     STM32_DMA_STREAM_ID_ANY
#define STM32_UART_USART2_RX_DMA_STREAM     STM32_DMA_STREAM_ID_ANY
#define STM32_UART_USART2_TX_DMA_STREAM     STM32_DMA_STREAM_ID_ANY
#define STM32_UART_USART3_RX_DMA_STREAM     STM32_DMA_STREAM_ID_ANY
#define STM32_UART_USART3_TX_DMA_STREAM     STM32_DMA_STREAM_ID_ANY
#define STM32_UART_UART4_RX_DMA_STREAM      STM32_DMA_STREAM_ID_ANY
#define STM32_UART_UART4_TX_DMA_STREAM      STM32_DMA_STREAM_ID_ANY
#define STM32_UART_UART5_RX_DMA_STREAM      STM32_DMA_STREAM_ID_ANY
#define STM32_UART_UART5_TX_DMA_STREAM      STM32_DMA_STREAM_ID_ANY
#define STM32_UART_USART6_RX_DMA_STREAM     STM32_DMA_STREAM_ID_ANY
#define STM32_UART_USART6_TX_DMA_STREAM     STM32_DMA_STREAM_ID_ANY
#define STM32_UART_UART7_RX_DMA_STREAM      STM32_DMA_STREAM_ID_ANY
#define STM32_UART_UART7_TX_DMA_STREAM      STM32_DMA_STREAM_ID_ANY
#define STM32_UART_UART8_RX_DMA_STREAM      STM32_DMA_STREAM_ID_ANY
#define STM32_UART_UART8_TX_DMA_STREAM      STM32_DMA_STREAM_ID_ANY
#define STM32_UART_USART1_DMA_PRIORITY      0
#define STM32_UART_USART2_DMA_PRIORITY      0
#define STM32_UART_USART3_DMA_PRIORITY      0
#define STM32_UART_UART4_DMA_PRIORITY       0
#define STM32_UART_UART5_DMA_PRIORITY       0
#define STM32_UART_USART6_DMA_PRIORITY      0
#define STM32_UART_UART7_DMA_PRIORITY       0
#define STM32_UART_UART8_DMA_PRIORITY       0
#define STM32_UART_DMA_ERROR_HOOK(uartp)    osalSysHalt("DMA failure")
 * USB driver system settings.
#define STM32_USB_USE_OTG1                  TRUE
#define STM32_USB_USE_OTG2                  FALSE
#define STM32_USB_OTG1_IRQ_PRIORITY         14
#define STM32_USB_OTG2_IRQ_PRIORITY         14
#define STM32_USB_OTG1_RX_FIFO_SIZE         512
#define STM32_USB_OTG2_RX_FIFO_SIZE         1024
#define STM32_USB_HOST_WAKEUP_DURATION      2
 * WDG driver system settings.
#define STM32_WDG_USE_IWDG                  FALSE
 * WSPI driver system settings.
#define STM32_WSPI_USE_QUADSPI1             FALSE
#define STM32_WSPI_QUADSPI1_PRESCALER_VALUE 1
#define STM32_WSPI_SET_CR_SSHIFT            TRUE
#define STM32_WSPI_QUADSPI1_MDMA_CHANNEL    STM32_MDMA_CHANNEL_ID_ANY
#define STM32_WSPI_QUADSPI1_MDMA_PRIORITY   1
#define STM32_WSPI_MDMA_ERROR_HOOK(wspip)   osalSysHalt("MDMA failure")
#endif /* MCUCONF_H */
halconf.h
 * @file    templates/halconf.h
 * @brief   HAL configuration header.
 * @details HAL configuration file, this file allows to enable or disable the
 *          various device drivers from your application. You may also use
 *          this file in order to override the device drivers default settings.
 * @addtogroup HAL_CONF
#ifndef HALCONF_H
#define HALCONF_H
#define _CHIBIOS_HAL_CONF_
#define _CHIBIOS_HAL_CONF_VER_9_0_
#include "mcuconf.h"
 * @brief   Enables the community drivers subsystem.
#if !defined(HAL_USE_COMMUNITY) || defined(__DOXYGEN__)
#define HAL_USE_COMMUNITY                  TRUE
 * @brief   Enables the PAL subsystem.
#if !defined(HAL_USE_PAL) || defined(__DOXYGEN__)
#define HAL_USE_PAL                         TRUE
 * @brief   Enables the ADC subsystem.
#if !defined(HAL_USE_ADC) || defined(__DOXYGEN__)
#define HAL_USE_ADC                         TRUE
 * @brief   Enables the CAN subsystem.
#if !defined(HAL_USE_CAN) || defined(__DOXYGEN__)
#define HAL_USE_CAN                         FALSE
 * @brief   Enables the cryptographic subsystem.
#if !defined(HAL_USE_CRY) || defined(__DOXYGEN__)
#define HAL_USE_CRY                         FALSE
 * @brief   Enables the DAC subsystem.
#if !defined(HAL_USE_DAC) || defined(__DOXYGEN__)
#define HAL_USE_DAC                         FALSE
#define HAL_USE_SDRAM           TRUE
#define HAL_USE_FSMC            TRUE
 * @brief   Enables the EFlash subsystem.
#if !defined(HAL_USE_EFL) || defined(__DOXYGEN__)
#define HAL_USE_EFL                         FALSE
 * @brief   Enables the GPT subsystem.
#if !defined(HAL_USE_GPT) || defined(__DOXYGEN__)
#define HAL_USE_GPT                         FALSE
 * @brief   Enables the I2C subsystem.
#if !defined(HAL_USE_I2C) || defined(__DOXYGEN__)
#define HAL_USE_I2C                         TRUE
 * @brief   Enables the I2S subsystem.
#if !defined(HAL_USE_I2S) || defined(__DOXYGEN__)
#define HAL_USE_I2S                         FALSE
 * @brief   Enables the ICU subsystem.
#if !defined(HAL_USE_ICU) || defined(__DOXYGEN__)
#define HAL_USE_ICU                         FALSE
 * @brief   Enables the MAC subsystem.
#if !defined(HAL_USE_MAC) || defined(__DOXYGEN__)
#define HAL_USE_MAC                         FALSE
 * @brief   Enables the MMC_SPI subsystem.
#if !defined(HAL_USE_MMC_SPI) || defined(__DOXYGEN__)
#define HAL_USE_MMC_SPI                     FALSE
 * @brief   Enables the PWM subsystem.
#if !defined(HAL_USE_PWM) || defined(__DOXYGEN__)
#define HAL_USE_PWM                         FALSE
 * @brief   Enables the RTC subsystem.
#if !defined(HAL_USE_RTC) || defined(__DOXYGEN__)
#define HAL_USE_RTC                         FALSE
 * @brief   Enables the SDC subsystem.
#if !defined(HAL_USE_SDC) || defined(__DOXYGEN__)
#define HAL_USE_SDC                         TRUE
 * @brief   Enables the SERIAL subsystem.
#if !defined(HAL_USE_SERIAL) || defined(__DOXYGEN__)
#define HAL_USE_SERIAL                      TRUE
 * @brief   Enables the SERIAL over USB subsystem.
#if !defined(HAL_USE_SERIAL_USB) || defined(__DOXYGEN__)
#define HAL_USE_SERIAL_USB                  FALSE
 * @brief   Enables the SIO subsystem.
#if !defined(HAL_USE_SIO) || defined(__DOXYGEN__)
#define HAL_USE_SIO                         FALSE
 * @brief   Enables the SPI subsystem.
#if !defined(HAL_USE_SPI) || defined(__DOXYGEN__)
#define HAL_USE_SPI                         TRUE
 * @brief   Enables the TRNG subsystem.
#if !defined(HAL_USE_TRNG) || defined(__DOXYGEN__)
#define HAL_USE_TRNG                        FALSE
 * @brief   Enables the UART subsystem.
#if !defined(HAL_USE_UART) || defined(__DOXYGEN__)
#define HAL_USE_UART                        FALSE
 * @brief   Enables the USB subsystem.
#if !defined(HAL_USE_USB) || defined(__DOXYGEN__)
#define HAL_USE_USB                         TRUE
 * @brief   Enables the WDG subsystem.
#if !defined(HAL_USE_WDG) || defined(__DOXYGEN__)
#define HAL_USE_WDG                         FALSE
 * @brief   Enables the WSPI subsystem.
#if !defined(HAL_USE_WSPI) || defined(__DOXYGEN__)
#define HAL_USE_WSPI                        FALSE
/* PAL driver related settings.                                              */
 * @brief   Enables synchronous APIs.
 * @note    Disabling this option saves both code and data space.
#if !defined(PAL_USE_CALLBACKS) || defined(__DOXYGEN__)
#define PAL_USE_CALLBACKS                   FALSE
#if !defined(PAL_USE_WAIT) || defined(__DOXYGEN__)
#define PAL_USE_WAIT                        FALSE
/* ADC driver related settings.                                              */
#if !defined(ADC_USE_WAIT) || defined(__DOXYGEN__)
#define ADC_USE_WAIT                        TRUE
 * @brief   Enables the @p adcAcquireBus() and @p adcReleaseBus() APIs.
#if !defined(ADC_USE_MUTUAL_EXCLUSION) || defined(__DOXYGEN__)
#define ADC_USE_MUTUAL_EXCLUSION            TRUE
/* CAN driver related settings.                                              */
 * @brief   Sleep mode related APIs inclusion switch.
#if !defined(CAN_USE_SLEEP_MODE) || defined(__DOXYGEN__)
#define CAN_USE_SLEEP_MODE                  TRUE
 * @brief   Enforces the driver to use direct callbacks rather than OSAL events.
#if !defined(CAN_ENFORCE_USE_CALLBACKS) || defined(__DOXYGEN__)
#define CAN_ENFORCE_USE_CALLBACKS           FALSE
/* CRY driver related settings.                                              */
 * @brief   Enables the SW fall-back of the cryptographic driver.
 * @details When enabled, this option, activates a fall-back software
 *          implementation for algorithms not supported by the underlying
 *          hardware.
 * @note    Fall-back implementations may not be present for all algorithms.
#if !defined(HAL_CRY_USE_FALLBACK) || defined(__DOXYGEN__)
#define HAL_CRY_USE_FALLBACK                FALSE
 * @brief   Makes the driver forcibly use the fall-back implementations.
#if !defined(HAL_CRY_ENFORCE_FALLBACK) || defined(__DOXYGEN__)
#define HAL_CRY_ENFORCE_FALLBACK            FALSE
/* DAC driver related settings.                                              */
#if !defined(DAC_USE_WAIT) || defined(__DOXYGEN__)
#define DAC_USE_WAIT                        TRUE
 * @brief   Enables the @p dacAcquireBus() and @p dacReleaseBus() APIs.
#if !defined(DAC_USE_MUTUAL_EXCLUSION) || defined(__DOXYGEN__)
#define DAC_USE_MUTUAL_EXCLUSION            TRUE
/* I2C driver related settings.                                              */
 * @brief   Slave mode API enable switch.
 * @note    The low level driver must support this capability.
#if !defined(I2C_ENABLE_SLAVE_MODE)
#define I2C_ENABLE_SLAVE_MODE               FALSE
 * @brief   Enables the mutual exclusion APIs on the I2C bus.
#if !defined(I2C_USE_MUTUAL_EXCLUSION) || defined(__DOXYGEN__)
#define I2C_USE_MUTUAL_EXCLUSION            TRUE
/* MAC driver related settings.                                              */
 * @brief   Enables the zero-copy API.
#if !defined(MAC_USE_ZERO_COPY) || defined(__DOXYGEN__)
#define MAC_USE_ZERO_COPY                   FALSE
 * @brief   Enables an event sources for incoming packets.
#if !defined(MAC_USE_EVENTS) || defined(__DOXYGEN__)
#define MAC_USE_EVENTS                      TRUE
/* MMC_SPI driver related settings.                                          */
 * @brief   Timeout before assuming a failure while waiting for card idle.
 * @note    Time is in milliseconds.
#if !defined(MMC_IDLE_TIMEOUT_MS) || defined(__DOXYGEN__)
#define MMC_IDLE_TIMEOUT_MS                 1000
 * @brief   Mutual exclusion on the SPI bus.
#if !defined(MMC_USE_MUTUAL_EXCLUSION) || defined(__DOXYGEN__)
#define MMC_USE_MUTUAL_EXCLUSION            TRUE
/* SDC driver related settings.                                              */
 * @brief   Number of initialization attempts before rejecting the card.
 * @note    Attempts are performed at 10mS intervals.
#if !defined(SDC_INIT_RETRY) || defined(__DOXYGEN__)
#define SDC_INIT_RETRY                      100
 * @brief   Include support for MMC cards.
 * @note    MMC support is not yet implemented so this option must be kept
 *          at @p FALSE.
#if !defined(SDC_MMC_SUPPORT) || defined(__DOXYGEN__)
#define SDC_MMC_SUPPORT                     FALSE
 * @brief   Delays insertions.
 * @details If enabled this options inserts delays into the MMC waiting
 *          routines releasing some extra CPU time for the threads with
 *          lower priority, this may slow down the driver a bit however.
#if !defined(SDC_NICE_WAITING) || defined(__DOXYGEN__)
#define SDC_NICE_WAITING                    TRUE
 * @brief   OCR initialization constant for V20 cards.
#if !defined(SDC_INIT_OCR_V20) || defined(__DOXYGEN__)
#define SDC_INIT_OCR_V20                    0x50FF8000U
 * @brief   OCR initialization constant for non-V20 cards.
#if !defined(SDC_INIT_OCR) || defined(__DOXYGEN__)
#define SDC_INIT_OCR                        0x80100000U
/* SERIAL driver related settings.                                           */
 * @brief   Default bit rate.
 * @details Configuration parameter, this is the baud rate selected for the
 *          default configuration.
#if !defined(SERIAL_DEFAULT_BITRATE) || defined(__DOXYGEN__)
#define SERIAL_DEFAULT_BITRATE              38400
 * @brief   Serial buffers size.
 * @details Configuration parameter, you can change the depth of the queue
 *          buffers depending on the requirements of your application.
 * @note    The default is 16 bytes for both the transmission and receive
 *          buffers.
#if !defined(SERIAL_BUFFERS_SIZE) || defined(__DOXYGEN__)
#define SERIAL_BUFFERS_SIZE                 16
/* SIO driver related settings.                                              */
#if !defined(SIO_DEFAULT_BITRATE) || defined(__DOXYGEN__)
#define SIO_DEFAULT_BITRATE                 38400
 * @brief   Support for thread synchronization API.
#if !defined(SIO_USE_SYNCHRONIZATION) || defined(__DOXYGEN__)
#define SIO_USE_SYNCHRONIZATION             TRUE
/* SERIAL_USB driver related setting.                                        */
 * @brief   Serial over USB buffers size.
 * @details Configuration parameter, the buffer size must be a multiple of
 *          the USB data endpoint maximum packet size.
 * @note    The default is 256 bytes for both the transmission and receive
 *          buffers.
#if !defined(SERIAL_USB_BUFFERS_SIZE) || defined(__DOXYGEN__)
#define SERIAL_USB_BUFFERS_SIZE             256
 * @brief   Serial over USB number of buffers.
 * @note    The default is 2 buffers.
#if !defined(SERIAL_USB_BUFFERS_NUMBER) || defined(__DOXYGEN__)
#define SERIAL_USB_BUFFERS_NUMBER           2
/* SPI driver related settings.                                              */
#if !defined(SPI_USE_WAIT) || defined(__DOXYGEN__)
#define SPI_USE_WAIT                        TRUE
 * @brief   Inserts an assertion on function errors before returning.
#if !defined(SPI_USE_ASSERT_ON_ERROR) || defined(__DOXYGEN__)
#define SPI_USE_ASSERT_ON_ERROR             TRUE
 * @brief   Enables the @p spiAcquireBus() and @p spiReleaseBus() APIs.
#if !defined(SPI_USE_MUTUAL_EXCLUSION) || defined(__DOXYGEN__)
#define SPI_USE_MUTUAL_EXCLUSION            TRUE
 * @brief   Handling method for SPI CS line.
#if !defined(SPI_SELECT_MODE) || defined(__DOXYGEN__)
#define SPI_SELECT_MODE                     SPI_SELECT_MODE_PAD
/* UART driver related settings.                                             */
#if !defined(UART_USE_WAIT) || defined(__DOXYGEN__)
#define UART_USE_WAIT                       FALSE
 * @brief   Enables the @p uartAcquireBus() and @p uartReleaseBus() APIs.
#if !defined(UART_USE_MUTUAL_EXCLUSION) || defined(__DOXYGEN__)
#define UART_USE_MUTUAL_EXCLUSION           FALSE
/* USB driver related settings.                                              */
#if !defined(USB_USE_WAIT) || defined(__DOXYGEN__)
#define USB_USE_WAIT                        FALSE
/* WSPI driver related settings.                                             */
#if !defined(WSPI_USE_WAIT) || defined(__DOXYGEN__)
#define WSPI_USE_WAIT                       TRUE
 * @brief   Enables the @p wspiAcquireBus() and @p wspiReleaseBus() APIs.
#if !defined(WSPI_USE_MUTUAL_EXCLUSION) || defined(__DOXYGEN__)
#define WSPI_USE_MUTUAL_EXCLUSION           TRUE
#if !defined(HAL_USE_FSMC) || defined(__DOXYGEN__)
#endif /* HALCONF_H */
board.h
/* ===================== SDMMC1 PIN MAPPING ===================== */
/* PC8  = SDMMC1_D0 */
/* PC9  = SDMMC1_D1 */
/* PC10 = SDMMC1_D2 */
/* PC11 = SDMMC1_D3 */
/* PC12 = SDMMC1_CK */
/* PD2  = SDMMC1_CMD */
#define GPIOC_SDMMC1_D0   8U
#define GPIOC_SDMMC1_D1   9U
#define GPIOC_SDMMC1_D2   10U
#define GPIOC_SDMMC1_D3   11U
#define GPIOC_SDMMC1_CK   12U
#define GPIOD_SDMMC1_CMD  2U
/* GPIOC config */
#define VAL_GPIOC_MODER   ( \
  PIN_MODE_ALTERNATE(GPIOC_SDMMC1_D0) | \
  PIN_MODE_ALTERNATE(GPIOC_SDMMC1_D1) | \
  PIN_MODE_ALTERNATE(GPIOC_SDMMC1_D2) | \
  PIN_MODE_ALTERNATE(GPIOC_SDMMC1_D3) | \
  PIN_MODE_ALTERNATE(GPIOC_SDMMC1_CK) )
#define VAL_GPIOC_OTYPER  ( \
  PIN_OTYPE_PUSHPULL(GPIOC_SDMMC1_D0) | \
  PIN_OTYPE_PUSHPULL(GPIOC_SDMMC1_D1) | \
  PIN_OTYPE_PUSHPULL(GPIOC_SDMMC1_D2) | \
  PIN_OTYPE_PUSHPULL(GPIOC_SDMMC1_D3) | \
  PIN_OTYPE_PUSHPULL(GPIOC_SDMMC1_CK) )
#define VAL_GPIOC_OSPEEDR ( \
  PIN_OSPEED_HIGH(GPIOC_SDMMC1_D0) | \
  PIN_OSPEED_HIGH(GPIOC_SDMMC1_D1) | \
  PIN_OSPEED_HIGH(GPIOC_SDMMC1_D2) | \
  PIN_OSPEED_HIGH(GPIOC_SDMMC1_D3) | \
  PIN_OSPEED_HIGH(GPIOC_SDMMC1_CK) )
#define VAL_GPIOC_PUPDR   ( \
  PIN_PUPDR_PULLUP(GPIOC_SDMMC1_D0) | \
  PIN_PUPDR_PULLUP(GPIOC_SDMMC1_D1) | \
  PIN_PUPDR_PULLUP(GPIOC_SDMMC1_D2) | \
  PIN_PUPDR_PULLUP(GPIOC_SDMMC1_D3) | \
  PIN_PUPDR_FLOATING(GPIOC_SDMMC1_CK) )
#define VAL_GPIOC_AFRH ( \
  PIN_AFIO_AF(GPIOC_SDMMC1_D0, 12U) | \
  PIN_AFIO_AF(GPIOC_SDMMC1_D1, 12U) | \
  PIN_AFIO_AF(GPIOC_SDMMC1_D2, 12U) | \
  PIN_AFIO_AF(GPIOC_SDMMC1_D3, 12U) | \
  PIN_AFIO_AF(GPIOC_SDMMC1_CK, 12U) )
/* GPIOD config */
#define VAL_GPIOD_MODER   PIN_MODE_ALTERNATE(GPIOD_SDMMC1_CMD)
#define VAL_GPIOD_OTYPER  PIN_OTYPE_PUSHPULL(GPIOD_SDMMC1_CMD)
#define VAL_GPIOD_OSPEEDR PIN_OSPEED_HIGH(GPIOD_SDMMC1_CMD)
#define VAL_GPIOD_PUPDR   PIN_PUPDR_PULLUP(GPIOD_SDMMC1_CMD)
#define VAL_GPIOD_AFRL    PIN_AFIO_AF(GPIOD_SDMMC1_CMD, 12U)
Any help would be greatly appreciated.
Thank you very much.
Re: STM32H743 SDMMC1 completely dead (no clock, no flags) on STM32H743
H7 is tested in the RT-VFS-HAL application (H735), you may use that application as reference, SDMMC is the same on all H7s.
Problems are usually caused by 1) Clock settings 2) GPIO settings 3) cache issues (but you need SDMMC working), you need to investigate there. Make sure SDMMC is getting its clock as expected, missing clock could explain registers reading all as zeros.
About board files? did you edit those manually or used the generator tool?
Ah, that application is present in trunk code only, you may try to checkout trunk code, it is normally very stable. I will backport the application to 21.11.5 next month.
This is the mcuconf.h in the demo:
#ifndef MCUCONF_H
#define MCUCONF_H
 * STM32H723/33/25/35 drivers configuration.
 * IRQ priorities:
 * DMA priorities:
#define STM32H723_MCUCONF
#define STM32H733_MCUCONF
#define STM32H725_MCUCONF
#define STM32H735_MCUCONF
 * General settings.
#define STM32_NOCACHE_ENABLE                TRUE
 * very critical.
#define STM32_VOS                           STM32_VOS_SCALE0
#define STM32_PWR_CR3                       (PWR_CR3_SMPSEN | PWR_CR3_USB33DEN)
#define STM32_CSI_ENABLED                   TRUE
#define STM32_LSE_ENABLED                   TRUE
#define STM32_PLL1_DIVM_VALUE               10
#define STM32_PLL1_DIVN_VALUE               208
#define STM32_PLL1_DIVP_VALUE               1
#define STM32_PLL1_DIVR_VALUE               4
#define STM32_PLL2_DIVM_VALUE               10
#define STM32_PLL2_DIVN_VALUE               200
#define STM32_PLL2_FRACN_VALUE              0
#define STM32_PLL2_DIVP_VALUE               40
#define STM32_PLL2_DIVQ_VALUE               8
#define STM32_PLL2_DIVR_VALUE               10
#define STM32_PLL3_Q_ENABLED                TRUE
#define STM32_PLL3_DIVM_VALUE               10
#define STM32_PLL3_DIVN_VALUE               192
#define STM32_PLL3_DIVP_VALUE               10
#define STM32_PLL3_DIVQ_VALUE               10
#define STM32_PLL3_DIVR_VALUE               10
#define STM32_RTCSEL                        STM32_RTCSEL_LSE_CK
#define STM32_D1HPRE                        STM32_D1HPRE_DIV4
#define STM32_D1PPRE3                       STM32_D1PPRE3_DIV1
#define STM32_D2PPRE1                       STM32_D2PPRE1_DIV1
#define STM32_D2PPRE2                       STM32_D2PPRE2_DIV1
#define STM32_D3PPRE4                       STM32_D3PPRE4_DIV1
#define STM32_CKPERSEL                      STM32_CKPERSEL_HSE_CK
#define STM32_SDMMCSEL                      STM32_SDMMCSEL_PLL2_R_CK
#define STM32_OCTOSPISEL                    STM32_OCTOSPISEL_HCLK
#define STM32_FDCANSEL                      STM32_FDCANSEL_HSE_CK
#define STM32_CECSEL                        STM32_CECSEL_LSE_CK
#define STM32_USBSEL                        STM32_USBSEL_PLL3_Q_CK
#define STM32_I2C1235SEL                    STM32_I2C1235SEL_PCLK1
#define STM32_USART16910SEL                 STM32_USART16910SEL_PCLK2
#define STM32_ADCSEL                        STM32_ADCSEL_PLL2_P_CK
#define STM32_IRQ_FDCAN3_PRIORITY           10
#define STM32_IRQ_OCTOSPI1_PRIORITY         10
#define STM32_IRQ_OCTOSPI2_PRIORITY         10
#define STM32_IRQ_UART9_PRIORITY            12
#define STM32_IRQ_USART10_PRIORITY          12
#define STM32_ADC_USE_ADC12                 FALSE
#define STM32_ADC_ADC12_CLOCK_MODE          ADC_CCR_CKMODE_AHB_DIV4
#define STM32_CAN_USE_FDCAN3                FALSE
#define STM32_I2C_USE_I2C2                  FALSE
#define STM32_I2C_USE_I2C5                  FALSE
#define STM32_I2C_I2C5_RX_DMA_STREAM        STM32_DMA_STREAM_ID_ANY
#define STM32_I2C_I2C5_TX_DMA_STREAM        STM32_DMA_STREAM_ID_ANY
#define STM32_I2C_I2C5_IRQ_PRIORITY         5
#define STM32_I2C_I2C5_DMA_PRIORITY         3
#define STM32_SDC_USE_SDMMC2                TRUE
#define STM32_SERIAL_USE_USART1             FALSE
#define STM32_SERIAL_USE_USART3             TRUE
#define STM32_SERIAL_USE_UART5              FALSE
#define STM32_SERIAL_USE_UART9              FALSE
#define STM32_SERIAL_USE_USART10            FALSE
#define STM32_SIO_USE_UART9                 FALSE
#define STM32_SIO_USE_USART10               FALSE
#define STM32_SPI_USE_SPI2                  FALSE
#define STM32_SPI_USE_SPI3                  FALSE
#define STM32_SPI_USE_SPI5                  FALSE
#define STM32_UART_USE_UART9                FALSE
#define STM32_UART_USE_USART10              FALSE
#define STM32_UART_UART9_RX_DMA_STREAM      STM32_DMA_STREAM_ID_ANY
#define STM32_UART_UART9_TX_DMA_STREAM      STM32_DMA_STREAM_ID_ANY
#define STM32_UART_USART10_RX_DMA_STREAM    STM32_DMA_STREAM_ID_ANY
#define STM32_UART_USART10_TX_DMA_STREAM    STM32_DMA_STREAM_ID_ANY
#define STM32_UART_UART9_DMA_PRIORITY       0
#define STM32_UART_USART10_DMA_PRIORITY     0
#define STM32_WSPI_USE_OCTOSPI1             FALSE
#define STM32_WSPI_USE_OCTOSPI2             FALSE
#define STM32_WSPI_OCTOSPI1_PRESCALER_VALUE 1
#define STM32_WSPI_OCTOSPI2_PRESCALER_VALUE 1
#define STM32_WSPI_OCTOSPI1_SSHIFT          FALSE
#define STM32_WSPI_OCTOSPI2_SSHIFT          FALSE
#define STM32_WSPI_OCTOSPI1_DHQC            FALSE
#define STM32_WSPI_OCTOSPI2_DHQC            FALSE
#define STM32_WSPI_OCTOSPI1_MDMA_CHANNEL    STM32_MDMA_CHANNEL_ID_ANY
#define STM32_WSPI_OCTOSPI2_MDMA_CHANNEL    STM32_MDMA_CHANNEL_ID_ANY
#define STM32_WSPI_OCTOSPI1_MDMA_PRIORITY   1
#define STM32_WSPI_OCTOSPI2_MDMA_PRIORITY   1
#define STM32_WSPI_OCTOSPI1_MDMA_IRQ_PRIORITY 10
#define STM32_WSPI_OCTOSPI2_MDMA_IRQ_PRIORITY 10
#define STM32_WSPI_DMA_ERROR_HOOK(wspip)    osalSysHalt("MDMA failure")
