Hi, Giovanni I did some tests with the lwip and fatfs together as a web server (files are read from the card and transmitted as web pages) but it looks extremely slow 1kB a second. Do you have any idea why it is so slow ?
It depends, how data is read and written? in general small blocks hurt performance. Try to isolate the problem, first lwIP without FatFS then reversal.
I cannot figure out if the ETHERNET driver is using DMA or not? Do you know if it is with DMA if not do you plan to use it ? Is there any samples of the usage of your DMA driver?
Best regards, Todor
