ChibiStudio for linux
Re: ChibiStudio for linux
Uhm, shouldn't the 32bits version work under the 64bits Linux, under windows apparently it does.
I don't have a 64bits OS to test on.
tinito
Post by tinito »
I've tried today with a linux mint 13 64bit, and eclipse didn't start.
I think you need a 32bit java VM (which should run on a 64bit machine, with some compatibility packages you generally have on 64bit systems), but if you have a 64bit java VM it will not run a 32bit eclipse (wasn't java introduced for portability? lol).
Some googling brings to the same suggestions, but I didn't try..
Hello tintio,
Thanks for your good work so far. I am very interested in a linux version of ChibiStudio.
I do run Arch Linux x86_64. Why don't you make two packages, a 32-bit and a 64-bit version. Would that be too much work?
Sadly, I don't have the time to actively contribute, but if you need anyone to test, I'm here.
tinito
Post by tinito »
Hi Tectu,
that would be the simplest solution to try but not the easiest to mantain (it actually doubles the work ;D).
A different workaround is to include a 32-bit JRE in the .tar.gz and specify that VM in eclipse.ini... not the best solution, but this would bring to a single package for both architectures. Do you think this would be too "dirty"?
Tomorrow I'll try to do that on a 64-bit machine to see if it actually works as expected.
For my personal opinion, I would find that this would be too dirty. But hey, it's java - a bit more of dirty-ness cannot make things worse ;-)
Keep me up to date, would be very interested.
We could put both 32 and 64 bits versions in the same package and make some kind of check in the launch script. I would duplicate ONLY the Eclipse executable, plugins and stuff should be portable.
That's indeed a good solution.
tinito
Post by tinito »
Going to try that, would be perfect.
tinito
Post by tinito »
I wasn't able to wait until tomorrow, I gave it a try right now on a 64-bit virtualbox machine.
Unfortunately it seems more complicated than just use the 64-bit executable, if I overwrite the eclipse binary with the 64-bit one i get the following error, which refers to a plugin:
tino@xubuntu-64:~/Desktop/ChibiStudio/eclipse$ ./eclipse
/home/tino/Desktop/ChibiStudio/eclipse//plugins/org.eclipse.equinox.launcher.gtk.linux.x86_1.1.200.v20120522-1813/eclipse_1502.so: wrong ELF class: ELFCLASS32
There are some plugins containing binaries apparently, we could fix that by hot-swapping ./eclipse/plugins in the launch script. That dir could become a symbolic link to plugins_32 or plugins_64.
Not a big deal, the hard part is to maintain the workspace.
