ChibiOS OpenOCD support
mabl
Re: ChibiOS OpenOCD support
Post by mabl »
Hi saraben,
most of your outputs look great. What is really interesting, is that your backtrace goes further back than then _port_thread_start functions:
      Thread [4] 536877952 (shell :  : WTQUEUE) (Suspended : Container)
         chSchGoSleepS() at chschd.c:122 0x8001664
         chSchGoSleepTimeoutS() at chschd.c:195 0x8001768
         qwait() at chqueues.c:69 0x8003c40
         chIQReadTimeout() at chqueues.c:232 0x8003e6c
         read() at serial.c:63 0x800574e
         shellGetLine() at shell.c:261 0x80134c6
         shell_thread() at shell.c:155 0x801328a
         _port_thread_start() at chcore_v7m.c:255 0x8000d32
         chSchGoSleepS() at chschd.c:121 0x8001664
         0xaa52432a
This should not be. For me it looks like this:
Thread 8 (Thread 536901664):
#0  0x080009f2 in chSchGoSleepTimeoutS (newstate=<value optimized out>, time=<value optimized out>) at ../../os/kernel/src/chschd.c:195
#1  0x08001b3e in chMBFetchS (mbp=0x20008c28, msgp=0x20007c94, time=<value optimized out>) at ../../os/kernel/src/chmboxes.c:335
#2  0x0800a480 in sys_arch_mbox_fetch (mbox=<value optimized out>, msg=<value optimized out>, timeout=<value optimized out>) at ../../os/various/lwip_bindings/arch/sys_arch.c:169
#3  0x080110ea in netconn_accept (conn=0x20004d48, new_conn=0x20007cb0) at ../../ext/lwip/src/api/api_lib.c:304
#4  0x08014876 in http_server (p=<value optimized out>) at web/web.c:115
#5  0x0800068a in _port_thread_start () at ../../os/ports/GCC/ARMCMx/chcore_v7m.c:255
Backtrace stopped: frame did not save the PC
I have no idea though how gdb figures out that the PC was not saved. Maybe it is a toolchain error. Maybe we need to clean the lr register on _port_thread_start? Giovanni, do you have any idea what could cause this? I also tried with -O3 and it still worked for me.
saraben: You could also try to set a break point into one of those threads, so that it is the current thread. Check if the backtrace still contains these function calls before _port_thread_start.
Not sure, does backtrace stop on LR==0? you could easily test it. Back trace should never go past _port_thread_start anyway.
feanor
Post by feanor »
Hi mabl
feanor wrote:With Option "USE_FPU = no" the threaded debugging works. Thanks for your help.
Apparently I was a bit hasty with this statement. I get all the threads running in ChibiOS, but it is not possible for me to debug them correctly. Hitting a breakpoint does not open the corresponding thread but it ends every time in chSchGoSleepS(). Also single-stepping does not work, it stays also in chSchGoSleepS() and produces this output of openocd
Open On-Chip Debugger 0.7.0-dev-gcb69d06 (2012-10-07-15:02)
Licensed under GNU GPL v2
For bug reports, read
   http://openocd.sourceforge.net/doc/doxygen/bugs.html
adapter speed: 1000 kHz
srst_only separate srst_nogate srst_open_drain
Info : clock speed 1000 kHz
Info : stm32f4x.cpu: hardware has 6 breakpoints, 4 watchpoints
Info : accepting 'gdb' connection from 3333
Info : stm32f4x errata detected - fixing incorrect MCU_IDCODE
Info : device id = 0x10006413
Info : flash size = 1024kbytes
Warn : acknowledgment received, but no packet pending
undefined debug reason 6 - target needs reset
flash 'stm32f2x' found at 0x08000000
ERROR: last sector must be <= 11
in procedure 'flash'
target state: halted
target halted due to debug-request, current mode: Thread
xPSR: 0x01000000 pc: 0x08002670 msp: 0x20000400
background polling: on
TAP: stm32f4x.cpu (enabled)
stm32x mass erase complete
target halted due to breakpoint, current mode: Thread
xPSR: 0x61000000 pc: 0x20000042 msp: 0x20000400
wrote 84080 bytes from file ../stm32-mf-chibios/src/build/chibi-mf.elf in 2.188476s (37.519 KiB/s)
Warn : negative acknowledgment, but no packet pending
Info : dropped 'gdb' connection
requesting target halt and executing a soft reset
Info : should no be called
Auto-detected RTOS: ChibiOS
Info : Successfully loaded memory map of ChibiOS/RT target running version 2.5.1
Error: ChibiOS registry integrity check failed, NULL pointer
Info : Only showing current execution because of a broken ChibiOS thread registry.
Error: address + size wrapped(0xffffffff, 0x00000004)
Error: ChibiOS registry integrity check failed, double linked list violation
Error: null stack pointer in thread
Info : halted: PC: 0x08010b12
Info : halted: PC: 0x08010b14
Info : halted: PC: 0x08010a90
Info : halted: PC: 0x08010b1a
Info : halted: PC: 0x08010b1e
Info : halted: PC: 0x08010b22
Info : halted: PC: 0x08010b24
Info : halted: PC: 0x080098c0
Info : halted: PC: 0x08010b10
saraben
Post by saraben »
Mabl,
To run the code yesterday, I downloaded the latest Chibios from GitHub and added a test application I was using. It appeared to be running OK.
The code has a shell, and number of GPIO interrupts set up so perhaps it was potentially confusing, adding problems with new kernal/application integration.
I went back to the demo code ARMCM3-STM32F103 with some i/o changes to match my board in the new kernal. The selftest code all ran fine.
This may be helpful for others trying to test the code as well a check.
I then tried that with your openOCD and it looks much better. At startup.
openOCD_test Default [GDB Hardware Debugging]
   ch.elf
      Thread [3] 536875472 (blinker :  : SLEEPING) (Suspended : Container)
         chSchGoSleepS() at chschd.c:122 0x8000990
         chSchGoSleepTimeoutS() at chschd.c:190 0x8000a6a
         chThdSleep() at chthreads.c:290 0x8000ed8
         Thread1() at main.c:37 0x8009ea6
         _port_thread_start() at chcore_v7m.c:255 0x80003cc
      Thread [2] 536873192 (idle :  : CURRENT) (Suspended : Container)
         _idle_thread() at chsys.c:61 0x8000508
      Thread [1] 536873384 (main :  : SLEEPING) (Suspended : User Request)
         0x8000508
         main() at main.c:77 0x8009f14
   gdb
The last entry in Thread 1 does not look complete
After Resume Pause
   ch.elf
      Thread [3] 536875472 (blinker :  : SLEEPING) (Suspended : Signal : SIGINT:Interrupt)
         Thread1() at main.c:35 0x8009e90
      Thread [1] 536873384 (main :  : SLEEPING) (Suspended : Container)
   gdb
All looks as expected
After resuming to a breakpoint in blinker
   ch.elf
      Thread [4] 536873472 (\250\t :  : READY) (Suspended : Container)
         Thread1() at main.c:36 0x8009e90
      Thread [3] 536875472 (blinker :  : CURRENT) (Suspended : Signal : SIGTRAP:Trace/breakpoint trap)
      Thread [2] 536873192 (idle :  : READY) (Suspended : Container)
         chSchDoRescheduleBehind() at chschd.c:309 0x8000b88
         chSchDoReschedule() at chschd.c:363 0x8000c36
         _port_switch_from_isr() at chcore_v7m.c:203 0x8000394
   gdb
So far so good.
Then removing the breakpoint and resume then pause
   ch.elf
      Thread [5] 536873384 (main :  : SLEEPING) (Suspended : Container)
   gdb
Looks good.
Now there is one issue I do not understand and it does not appear correct.
When running openOCD with gdb in the past, going Resume Pause virtually always ended in _idle_thread as expected as the processor is doing very little.
Now however doing the same ends in the chSchGoSleepS in the main loop every time I try.
Does the openOCD RTOS code modify the idle thread?
I also notice that I cannot break in the idle thread.
I setup to run the old openOCD with the same code and openOCD configuration files. It stops in the loop in _idle_thread every time I try.
Now comparing with my application, I have a number of Debug flags set in chconfig.h, so I trided the same flags in ths simple code and setting
CH_DBG_SYSTEM_STATE_CHECK        TRUE
results in the same behaviour as my application code.
Just for completeness I tested the following
CH_DBG_SYSTEM_STATE_CHECK        TRUE    NO GOOD
CH_DBG_ENABLE_CHECKS         TRUE   OK
CH_DBG_ENABLE_ASSERTS         TRUE   OK
CH_DBG_ENABLE_TRACE             TRUE   OK
CH_DBG_ENABLE_STACK_CHECK       TRUE   OK
CH_DBG_FILL_THREADS             TRUE   OK
CH_DBG_THREADS_PROFILING        TRUE   OK
When running in the state with CH_DBG_SYSTEM_STATE_CHECK set, if I continue to run to breakpoints, it keeps creating new threads, like Thread 4 in the breakpoint case above, but a new one every time.
I do not know if having that flag set is valid when running openOCD.
I hope this helps.
Regards
saraben
Post by saraben »
Mabl,
Another problem which may also relate to the info above.
When a breakpoint is set, it sometimes stops at the end of one of the chSchGoSleepS routines. Not always the same one.
It appears to break at the correct time, due to external input or regular events, but indicates this routine.
It will sometimes do this once then the correct break, sometimes it gets stuck repetatively.
Regards saraben
mabl
Post by mabl »
Hi saraben,
thanks for this great report! Today I did some real work debuging work in eclipse (i was using gdb directly before) and I was also not happy with the results shown in eclipse. It's hard to tell what exactly is wrong - but threads tend to display "wrongly".
I've discovered a workaround though: There are TWO debug frameworks in eclipse. I think you are currently using the "GDB (DSF) Hardware Debugging Launcher" while Giovannis ChibiOS plugin also only works with "Standard GDB Hardware Debugging Launcher"! The "Standard Launcher" gives me FAR better results - also on breakpoints! One problem though: Thread names are not displayed with it *grrrr* :twisted:
This also explains the "unresolved symbols"! You will have to check "Load Image" and "Load Symbols" checkboxes and in addition use the file command with the FULL path of the ELF. Here is an example screenshot:
Note, the selected debug launcher and the "file" command as well as the checked "Load image/symbols".
The other stuff:
saraben wrote:Mabl,
   ch.elf
         0x8000508
   gdb
Thread1 is the main thread and special. It is ok the way it is displayed.
saraben, could you give it a try again with the Default debug launcher?
Badger
Post by Badger »
Nice work mabl. I managed to get it to work with SublimeGDB:
Now I must hack SublimeGDB some more so that it actually works nicely for embedded development!
mabl
Post by mabl »
Ok, I checked out a lot of different IDEs: Netbeans, Code::Blocks, codelite - all had issues. But I think I just fell in love with qt creator:
mabl
Post by mabl »
Probably I still need a right startup file here. But it worked magically for now.
I had no idea it could be used for embedded.
