i got a Problem when i use the HAL without the RT using the ADC. The function adc_lld_vreg_on called by adc_lld_start uses the macro US2RTC which is part of chsys.h. Do i have to define all those macros by myself in a module like osal or is this a bug?
Thanks
Dependency between HAL and RT
Re: Dependency between HAL and RT
It is a bug, drivers are supposed to use only OSAL function, I will look into it.
You can replace it with code taken from chsys.h in the meanwhile, put the macro in halconf.h.
another HAL<-> RT Bug: Please have a look at dac_lld.c line 351and 439:
There are a RT debug function calls as well.
default:
chDbgAssert(false, "unexpected DAC mode");
break;
Please verify the SVN repository on sourceforge, the one on github is updated manually and I don't manage it.
